Not interested in new or a Model X for a variety of reasons
What have I missed about occasional towing a small trailer with a Model S?
Yes - Planning on 19" wheels
If it has to be a Model S, you definitely want the long range. I don’t think you’ll be able to tow and keep the car within the percentages you want. Honestly, for long trips, use the battery pack as much as you need it too. But you will likely have to stop two times on those trips to keep the battery pack within the range you want.Hello everyone! First post here on this forum and figured that it would be better to post in this thread vs create a new one that is very similar...
I'm looking at used Model S's and also trying to decide between a Standard or Plaid.
Some relevant details that are pertinent to the subject...
- I regularly make 250 mile one way trips ~40+ times a year, including Wisconsin winters
- I occasionally pull a small trailer (6.5x10 or 4x8 single axle)
- Looking at 2022-2023's that have the heat pump due to the above winter travel and distance
- I have level 2 charging available at each end of the 250 mile trips
- There are Tesla Super Chargers located at ~25% and ~75% of the trip
- I tend to keep vehicles a long time - have 400k on my current vehicle
I really would like to have ~500 miles of range, keep the charge between 20% and 80% and still have some reserve for things like heat, A/C, snow/rain, detours, battery degradation, etc and not have to stop at a charger every trip.
But with ~400 miles of range, keeping the charge between 15% and 85% and having a super charger at 25% and 75% of the trip, I'm rationalizing that I can make this work for most trips without stopping at a charger or significantly reduce the life of the battery. For the times that I do need to stop at a charger, the battery will have a minimum of 1 hour to condition, (typically 3 hours) and I should be able to charge for <10 minutes to get enough range to comfortably make it to my destination.
The EPA range is practically the same 396 vs 405, but practically is the Plaid just as efficient (or not?) as the standard when driving normally?
I've been reading and reading trying to educate myself - There's no practical reason to get a Plaid, but why not have the most powerful thing out there ?
If you’re not towing then, I would just get the long range. Save money and more range. It’s plenty quick enough too. And the 19 inch rims as well help the range.Got it - thanks for sharing that info. I have other vehicles that can tow the trailer, so if we leave that out of the equation, Plaid or Standard?
Go LRGot it - thanks for sharing that info. I have other vehicles that can tow the trailer, so if we leave that out of the equation, Plaid or Standard?
Off Topic I tested an S LR with white interior. Do you eyes get used to the bright white after a while?I agree with many others who posted in this thread; you should get the long range Model S. Please let us know what you decide, either way.
it's a disaster for cleaning and I also agree that it looks way too bright. Cream is the nicest and best interior for light colors. Looks really good, especially on Red, or Blue MS.Off Topic I tested an S LR with white interior. Do you eyes get used to the bright white after a while?
Reasons to go LR: Cheaper, more efficientThanks everyone for your opinions - Logic says the LR is the best option, but the Plaid is so tempting
Can anyone provide some technical reasons to go LR vs Plaid to support the above logic?
Despite the good advice given obviously you want the Plaid ...go for it. It's ok to make a car decision based on emotion vs logic sometimes.Thanks everyone for your opinions - Logic says the LR is the best option, but the Plaid is so tempting
You're also going used. Understand someone would've MOST LIKELY driven the plaid "harder" than a used Long Range. If you want to spend 10-15k extra on the open market and you're ok with the difference of price then go for the plaid. The range isn't that much of a difference if you're gonna get 19s on bothReasons to go LR: Cheaper, more efficient
Reasons to go Plaid: Hard to overstate the excitement of the acceleration in Plaid mode. Track mode.
Otherwise they’re basically the same car.
Exactly. I've changed 4 different cars the last 3 years and I work from home. I never need any of these cars but I just buy them go big or go home lolDespite the good advice given obviously you want the Plaid ...go for it. It's ok to make a car decision based on emotion vs logic sometimes.
Is it that obviousDespite the good advice given obviously you want the Plaid ...go for it. It's ok to make a car decision based on emotion vs logic sometimes.
Agreed that a plaid has likely has more abuse.You're also going used. Understand someone would've MOST LIKELY driven the plaid "harder" than a used Long Range. If you want to spend 10-15k extra on the open market and you're ok with the difference of price then go for the plaid. The range isn't that much of a difference if you're gonna get 19s on both
There’s no such thing as small or large drive units with these cars as far as I’m aware.I'm not looking to put anyone down or lift anyone on a pedestal here - just the facts
Plaid has 3 motors vs 2 in the standard
Is the Plaid using 3) Small Drive Units with carbon fiber wrap on the rotors?
Is the Standard using 1) Small Drive Unit in the front and 1) Large Drive Unit in the rear?
Do any of these 2022+ drive units have coolant leakage issues like the earlier drive units?
Is the 3 drive units on the Plaid the reason for it's slightly reduced efficiency/range?
Is there real world range difference between the two?
Any known issues that effect one and not the other?
I don’t know know if it’s a plus or not, but it’s just another difference.
