220V adapter for Airbnb - would that be helpful?
Discussion in 'Model S: Battery & Charging' started by BNBStudio, Mar 1, 2021 at 3:29 PM.
  1. cwerdna
    cwerdna Active Member
    SF Bay Area, CA
    #21 cwerdna, Mar 2, 2021 at 2:54 PM
    Re: XC40: Volvo’s first EV is stuck at cargo ports waiting for a software update is delayed for the US right now.
    FINAL UPDATE: Quarterly Plug-In EV Sales Scorecard is a list of EVs/PHEVs sold in the US for calendar year 2019. Off the top of my head, I'd estimate that at least 50 to 75% off the models there do NOT come with an L1/L2 EVSE which can be plugged into a NEMA 14-50 outlet. For some, maybe there's an optional adapter (e.g. Teslas) and for some, there's an unofficial and unsupported method (2017 to 2021 Bolts).
    And, for some, it varies by model/equipment level. Example: Not all 2018+ Leafs come with a L1/L2 NEMA 5-15/NEMA 14-50 EVSE. And, 2011 to 2017 US market ONLY come with an L1 120 volt NEMA 5-15 EVSE, just like ALL 2017 to 2021 Bolts.
    If you want to go by unit sales in the US, for calendar year 2020, I'd say it's likely 75+% do NOT come with an L1/L2 EVSE which can be plugged into a NEMA 14-50 outlet since Tesla dominates followed by Prius Prime and Bolt.
    Yep. Or, they can just hardwire a J1772 L2 EVSE.
  2. ucmndd
    ucmndd Well-Known Member
    I recently installed the 32 amp hardwired version of the Amazing E for our Pacifica PHEV. I'm quite pleased with the quality for the price.
  3. cwerdna
    SF Bay Area, CA
    And, I'm guessing that Pacifica PHEV didn't come with a L1/L2 EVSE that could plug into NEMA 5-15 and 14-50, right?
    Funny enough, there was another thread on this before and someone else at Adding a charger into an AirBnB also seconded what I said.
  4. ucmndd
    No, although I don’t think that’s a reasonable expectation for a plug in hybrid with a 16kwh battery. I DO think BEVs should include some manner of L2 charging equipment. It’s a shame so many of them don’t.
  5. user212_nr
    user212_nr Active Member
    US
    It is generally absorbed by the host. A Tesla battery is 50-75 kWh and you can expect that they will arrive with the battery completely depleted and leave with it charged.
    However, you can probably rely on them not needing much more than that if they stay for multiple nights, so the $3-$7 cost is split between all the nights.
    It is up to you whether you can increase your prices and still get the same number of customers, or whether you will get more customers at a lower price.
  6. Feathermerchan
    Feathermerchan Active Member
    Euless, Tx
    BNBStudio - I would put a picture of your garage outlet in your listing so people know what's there along with pictures of your Tesla Gan1 and Gan2 adaptors. As far as adding to your electric bill, you won't know unless you meter that outlet which is expensive. I'd just rent the Tesla adaptors for $5 or so per day or charge $5 more per day for those with electric cars ad access to the garage.
    Alternatively you may be able to access your house meter's usage from a utility web portal and look at the loads. When you see a step increase in kW of 240 V X 30 A X 0.8 = 5.8 kW or 5.8 kWh per hour then you know someone started charging. When it drops off in a few hours you know they have stopped. Then take how many hours times 5.8 and that's about how many kWh they used.
