Hi folks.
I took delivery of my M3P a couple of weeks ago and will be getting an Andersen charge point fitted. However, because I’m having work to the house done that won’t be until after Easter. To tide me over I’ve had a 32 Amp commando socket fitted and bought a dedicated charging lead (a Duosida). Problem is I’m only getting maximum of 20 Amp charge. The car screen shows “20/20” charge current, which I presume means the car thinks there is only 20 Amps available. I can’t increase this via the screen.
The control unit on the charge cable lets me set a current of 32, 16, 13 or 10 Amps. If I reduce it to 16, 13 or 10 Amps then the car screen shows the same. But when I increase it to 32 Amps the car still shows a charge rate of 20 Amps, 18 miles per hour and no way to increase it.
I don’t suppose many people use commando sockets, but I’d really appreciate it if anyone has any advice. Thanks!
