Here are some observations using 72 kW urban chargers vs 120 kW chargers. I have a Model S 100D. At a 72 kW charger charged from 29% to 80% = 168 miles. Got a nice constant 74kW, at close to 80% it tapered down.
Whole charge took 42 minutes. Unlike the 120kW chargers these are not paired, so you get full current.
At a 120kW charger this would take about 32 minutes. So, at 72 kW it was just 10 minutes more.
At Qualcomm with their 120kW chargers if your neighbor is already charging, this would also take 40+ minutes for you.
Come on, this ain't the way that it works.
Best case, You pull into second port and first port has been there 40 minutes. You get about, let's say 20kW. But you get it for only 5 minutes, at which you become #1 and pull full charge. Added charge time about 3-4 minutes.
Worst case, First port pulls in minutes before you, You get 20 kW for 40 minutes and then full power. That ends up taking you about 70 minutes to charge.
Your average is going to be in-between the two, about 60 minutes.
When you look at the urban charger, the average time is actually going to be the SAME number.
The difference is that a road charger, can allow a faster charge, whereas a urban charger cannot.
Most chargers, outside the California area are sized appropriately, so that the average usage is less than half the number of chargers, allowing most users to charge fast.
The problem is California, where too many people are using too few Superchargers. Part of this is the number of cars, but a bigger part is the number of people not charging at home or office. And for those that don't charge at home or office, they end up clogging the chargers for everyone.
The different between the two chargers is that the classic road charger allows the opportunity for faster charging, while an urban charger doesn't.
And it's also one of those things that people outside of California look at and well, wish they would have a charger within 100 miles of them.
