xAgyex
I have had my setup through this mild winter in MD, and didn't notice any issues. But I also don't drive in deep snow if I can avoid it. Maybe if you drive in deep snow snow might clog the drain, but I am sure it would melt if parked in a garage for any amount of time even in winter. Clearly if it would freeze on top of the battery as intended by Tesla, then it can also freeze if hanging out like that. So far so good for me no issues.I was looking into doing this as well as my '13 P85 occasionally has some AC smells (although it has dissipated since installing a new cabin filter). I noticed on the Tesla Service manual (the one you could sign up and access back in May) that there is a detailed procedure on doing this (to the tune of 70 steps and some (what looks like) major interior parts removal. it's called 'Use Evaporator Foam Cleaner, Replace Cabin Filters' from April 2022 and says "This procedure is a DRAFT, although it has been validated."
Has anyone else seen this procedure? Obviously going right up the condenser drain line like that displayed here is probably the quickest method (but is it accomplishing the intent of the cleaning)? i really don't want to tear about half the car and spend half a day doing it when the condenser line method may accomplish the same thing.
Also, perhaps it might be more effective (and easier to snake the Kool-It cleaning line closer to the coils) to remove the drain line where it enters the firewall and spray from that location. Seems like a more direct route. One could put the cup to catch the fluids under the HVAC nipple (A) and the reattach the drain hose (B). the See attachment for details.
