jgrgnt
I just posted the following in another thread related to AC odor, so thought it might be useful/helpful to some to re-post it here...
_________________________________________________________________________
Here is some information that might help those of you who are still struggling with this odor/smell.
I too recently did the foam cleaning and cabin filter change myself. It definitely eliminated the smell. However, the smell I had prior to this service was not the moldy/musty smell that most everyone has been describing. My smell was more chemical in nature. Hard to describe exactly, but it was definitely noticeable. Thankfully, the smell only stuck around for the first 10 seconds or so after I initially turned on the cabin fan and/or AC. After that, the smell would completely dissipate/disappear. I took delivery of my vehicle almost 1 year ago (in early August 2019) and started noticing this chemical smell about 2 months ago.
When I called my local Tesla SC to order the OEM cabin filter, they thought it was a bit unusual to change the cabin filter so soon. So, I described the problem/smell to them. They looked up my VIN and quickly came back to inform me that Tesla has a newer/updated part for the HVAC system. It is called an "inner duct plenum" and is supposed to improve drainage in the HVAC system. I guess the "older" inner duct plenum design did not allow for complete/proper drainage of the condensate. So, this may be what is causing the smell to return for some or many Model 3 owners. My vehicle was built in July 2019. So, I do not know exactly when Tesla starting using this newer/updated "inner duct plenum" part in their production.
Attached is a copy of the Service Order from my local SC, which describes/shows the optional quote for the inner duct plenum (see line item #2). As you can see, the part itself is very inexpensive ($11) and labor to install is also inexpensive/reasonable at just $58. This can be done by Tesla mobile service. Therefore, I presume it would be a relatively easy DIY job for those who want to avoid the $58 labor charge.
I have decided to wait & see if my particular chemical smell returns. If it does return, then I'll probably either have Tesla change the inner duct plenum or buy the part and do it myself.
Hope this helps some and good luck!!
Good to know, thanks for sharing.
The part you referenced is #3 in this diagram. It appears to be on the frunk side of the firewall, so I wonder if its purpose is to drain water that collects in the intake tract, rather than condensation inside the HVAC assembly.
