After 8.0 software update dash camera power alternative
Discussion in 'Model S' started by Mike_Atieh, Sep 24, 2016.
Tags:
  1. Mike_Atieh
    Mike_Atieh New Member
    North Carolina
    after I updated to 8.0 my dash camera installed to loose connector by the microphone it used to have power all the time now after 8.0 it goes off when car is locked, any one have idea of another easy way to keep my camera on all the time.
  2. wolfson292
    wolfson292 Architect
    Florida
    I haven't noticed this but definitely will check. I am on 8.0 and have my dash cam wired that way.
  3. cman8
    cman8 Member
    United States
    Yes. Please reply if this is the case as I have mine wired there also and don't want to loose the always on capability
  4. andrewket
    andrewket Well-Known Member
    Uh oh. Mine is wired the same way...
  5. Todd Burch
    Todd Burch Voltage makes me tingle.
    Smithfield, VA
    I run my Blackvue 650 cord through the hinge area in the passenger side door, behind the front right quarter panel, and under the hood into the frunk area. Works great and you can't see a thing.
  6. rog
    rog Member
    Connecticut
    I have the same setup, and the cam keeps power even after the car is locked.
  7. cman8
    cman8 Member
    United States
    Are you on 8.0?
  8. rog
    rog Member
    Connecticut
    Yes.
  9. STbreaker
    STbreaker Member
    Long Island, NY
    I'm downloading my cam videos right now using a script @Brett wrote. So camera must still be getting power.
  10. andrewket
    What'a the script do? I've looking for an automated way to dump the video from the SD card over wifi to a NAS every time I pull into the garage.
  11. JPP
    JPP Active Member
    SF Bay Area, CA
    Both of our cars with Blackvues (550/650) hardwired into the 12v in the headliner under the grille work fine under v. 8. Are you absolutely sure that your installer used a meter to test out the point on the connector and is hooked up to the 12v and ground?
  12. STbreaker
    STbreaker Member
    Long Island, NY
    Basically you run it from the command prompt (with IP address flag) and it will download files on the SD card to the destination folder on your computer. It will skip any files already present in the target, so you do have to hold on to files until you reformat or they get written over for greatest efficiency. If you dig around the site a bit, he has a much more technical and robust description of how the script works and how he/others figured out the camera's file system if you're into coding and such... It was so much easier when you could just FTP into the thing...
    Link to release
  13. fallen888
    fallen888 Participant
    Newtown, PA
  14. cman8
    cman8 Member
    United States
  15. Mike_Atieh
    North Carolina
    thanks to everyone for help, but for some reason it's working now when car is off, it maybe connection issue, I will check my connection tomorrow
