Nichigo
My M3P is on order and safe to say I'm keeping the postman busy before it's even arrived! I've been looking at the TSW Tremblants . Has anyone fitted a staggered set of these to a M3P? How would the 20x8.5 5x114.3 ET: 30 / 20x10 5x114.3 ET: 40 combo sit in the arches with a 1" Eibach springs drop?
For the tyres what would be closer to the standard rolling circumference:
Front - 245/35/20 or 235/35/20?
Rear - 285/30/20 or 275/30/20?
Have attached my crude Photoshop of how the car is shaping up in my mind!
Thanks
You'll be missing the flush spec in the rear by about 15mm and in the front by about 22mm. If you're set on the rim widths, I'd recommend shooting for offsets closer to:
Front: +12mm
Rear: +28mm
If you can't get close to those offsets, then you may need to play with the rim widths. Just remember that every 0.5 inch you add to a rim width is equivalent to subtracting approx 6.3mm from the offset (and vice versa for going down in width).
Would also recommend the 245 and 285 tire combo.
