Generally me too. I think it’s where I’ll end up unless I see something that really convinces me to go bronze. And your pics are confirming my gunmetal bias! lol
Posted incorrectly on the tire thread at first....
I am looking for feedback on a set of track wheels.
Do yall think I'll be safe with enkei gtc02, 18x10.5+35 with falken rt660 285/30/18 ? Would 275/35/18 be better?
I have the MPP Stoptech BBK (as well as the rest of MPPs suspension components). I've heard mixed feedback on whether there will be caliper clearance issues.
10.5 wide +35 isn't going to clear the front inner knuckle. Assuming the Stoptech rotor is similar to the gryo disc rotors, you need more like +25. I can't speak for brake clearance. I'm also currently fighting mixed feedback from brake/wheel manufacturers on what will clear. It's frustrating.
Thanks for the reply! Hm...I had my alignment shop test fit my current rears (20x11+40, 285/30/20) on the front, and I was told there was sufficient clearance. That was before the brakes, which I believe should've just moved the hub out a few mm.
Interesting. I guess the knuckle does curve and sorta open up at a larger diameter. Check out the quest for wider tires thread. Someone recently couldn't fit 19x9.5 +35 w 275/35/19 which is why I say that. Given tire cross sections vary greatly, your rotors push the tire out a few mm and the 285/30/18 is pretty small overall diameter, I could be wrong (shrug).
