travass808
Love this look!No spacers.
I'm running a 275/35/18 tire, so ~1-1.2" smaller tire diameter than OEM. Had to roll front fenders.
I will lower another 1/2" and check alignment when I get air cup kit completed.
How are your HB003 holding up? Curious what your avg wh/mile is as well? Any feedback helps, thank you!They are 20x8.5 with 30mm offset wrapped in 245/35R20. So far finish seems good. Time will tell though.
What wheels are those ?
Artisa/Anovia Titans; Artisa/Anovia is a private-label brand from FitmentIndustries. Wanted something cheap and light (19lbs) to test these wheel specs/brake clearance with.What wheels are those ?
They have a nice concaveness to themArtisa/Anovia Titans; Artisa/Anovia is a private-label brand from FitmentIndustries. Wanted something cheap and light (19lbs) to test these wheel specs/brake clearance with.
That's what drew me to themThey have a nice concaveness to them
Should be fine. What size tire and how low are you going? May be a little poke if you don't have any camber/stock height.Anyone run a 10 rear on a +30 offset?
a set of wheels has come up but i think it might be a little too agressive in the rear.
Do you have any photos of the 20x11 setup ?Should be fine. What size tire and how low are you going? May be a little poke if you don't have any camber/stock height.
I'm running 20x11+40 in the rears for the daily set.
Alloy Wheel & Tyre Fitment Calculator. Offset, Tyre Stretch and Speedo Error | Will They Fit
Alloy Wheel & tyre fitment calculator - it calculates inset, poke, speedo error, tyre stretch and loads more.www.willtheyfit.com
Yeah if you could when you get time that would be great as I don’t think I will be running it that low I will just be running EibachsYea I have all the MPP parts so that alignment could be adjusted. OEM parts don't have much/any adjustability.
Rear fenders were not modified.
No closer up pics of fender arches. I could take some but car has been raised slightly since then.
Lol...VS Forged, VS06, 20x9.5+35, 20x11+40. That was when they were powdercoated Illusion Blue.
