Lindenwood
Other than the occasional show-off day, I only run this 275/35R19 +22 on race days with >3 degrees front camber and ~2.5 degrees rear camber. Not a daily setupIf you like to run a 275…look into a different brand. Not all 275 runs the same tread / section width. If you need a slight width reduction to run this daily without rubbing…consider adding a few more PSI. I’m assuming you’re rubbing on the very edge so putting a few more psi will stretch the sidewall a little bit and make the tire a little taller.
I hope this make sense.
