Love the 104s. Can you send me details of summer promo?
PM sent, please check. Take advantage of our summer sales before it ends
Where did you get those? I’m not sure if it’s a mistype but are they really 18.8lbs? For a 19?New track shoes are in!
Speedwell RS-1 19x9.5 +35 with 265/35 RE71.
Not hubcentric, so I picked up a set of 72.6-64.1.
Total weight with the tires/TPMS/metal valvestems and balance weights = ~47.5lbs (old digital bathroom scale)
View attachment 429343 View attachment 429345
An aggressive setup with Signature SV104.
-Long Range RWD
-F 20x9 ET25
-R 20x10.5 ET25
Any rubbing with this setup? How much is it lowered?
No rubbing with proper camber setting. You can see my post in this thread here: Aftermarket wheels and Tires #10
NICE! I was thinking on doing the same wheels but in 19s. You gonna drop it?Finally got my wheels. TSW Bathurst and Michelin Sport 4S. Staggered setup. Real happy with the look and stance. I was shooting for something lighter than the factory 20" 8.5" wheel and tire setup. Factory 20" is 53.2lbs. So I saved 12.8lbs total.
TSW Bathurst 20x9 ET30 Front - Tires 245/35/20 - Weight 48.8lb
TSW Bathurst 20x10 ET40 Rear - Tires 285/30/20 - Weight 51.2lb
View attachment 435429 View attachment 435430 View attachment 435431 View attachment 435432 View attachment 435433
Here is a pic of mine when I was on Bathurst 19sNICE! I was thinking on doing the same wheels but in 19s. You gonna drop it?
Anybody rolling on Enkie NT03 here? Looking to get 18x10.5 et 10 square setup.
Sorry it’s actually et30. My fat fingersMPP Visits Laguna Seca and Has a Record-Setting Party
I don't know the offset, but it's a tight fit. I doubt you'll make the +10 offset work.
Must be super tight! My 18x9.5 ET39 have 4mm of clearance from the wheel to the knuckle. Maybe if the shape of the barrel were different 18x10.5 ET30 could fit with a lot of camber like MPP was running. Also you'd need thicker rotor hats (the Performance rotors bring in the wheels by 3-4mm?)MPP Visits Laguna Seca and Has a Record-Setting Party
It will fit just fine at the rear, with about -1.8* camber and it will look real nice.(Assuming you are using 285 tires.)
However, the front you will need some additional work such as fender work, stretch tires and it will still be poking out quite a bit.
What size do you recommend for the front? I’m dropped on UP moderates.
