Yes! Blindfold test! Start with the 90+ MPH. No help from the screaming passengers allowed.Ed, we need someone like lolacarchamp to do a blindfold test in MS on 5.8 and MS on 5.9 to see if there's really noticeable ride difference. As a passenger, of course. I cannot advocate blindfolded driving.
I never had it to begin with. When I got my car 5.8 was applied at the SvcC despite my having told them to NOT apply it when my car came in. I AM experiencing a bit of a problem though. I very much like the increased speeds at which one can apply high and very high but I chose for my car to apply low at 50 MPH. This does not seem to work. It stays in normal unless I force it to go into low. If I select low it does drop into low stance. It just doesn't seem to want to do it at the designated speed.So, is it worth it?
Is your ride back?
When we had the original auto lowering you needed to be at 55mph for at least 1 minute before it would lower, is this not happening.I never had it to begin with. When I got my car 5.8 was applied at the SvcC despite my having told them to NOT apply it when my car came in. I AM experiencing a bit of a problem though. I very much like the increased speeds at which one can apply high and very high but I chose for my car to apply low at 50 MPH. This does not seem to work. It stays in normal unless I force it to go into low. If I select low it does drop into low stance. It just doesn't seem to want to do it at the designated speed.
RebootI never had it to begin with. When I got my car 5.8 was applied at the SvcC despite my having told them to NOT apply it when my car came in. I AM experiencing a bit of a problem though. I very much like the increased speeds at which one can apply high and very high but I chose for my car to apply low at 50 MPH. This does not seem to work. It stays in normal unless I force it to go into low. If I select low it does drop into low stance. It just doesn't seem to want to do it at the designated speed.
Yup...I ALWAYS reboot after an update. I rebooted and assured that the setting stayed then took it out for a test drive. No drop. With the screen up I watched it go immediately from very high to high, then from high to normal but NOT from normal to low. Checked it once more this morning. Setting was still correct. Rebooted again anyway and took it out for a breakfast spin. The instant she hit 50 MPH she dropped into low and it was VERY comforting!!! Checked it out a few more times before returning home with breakfast and it would seem that all is well now. I am not sure what caused it to NOT work yesterday, but I am happy that all seems well today.Reboot
Patiently awaiting....................
Actually with the timing of the belly pan reinforcement and the NHTSA announcement I'm going to retract that statement. I really was right since Tesla obviously knew about NHTSA's stance ahead of time :biggrin:I'm happy to have been proven wrong on this one :smile:
Actually it may be the exact height increase necessary to clear a very common, heavy object likely to be found on the road, a ball hitch. We already know of two Model S's that have impacted one, one of which resulted in a fire, the other in a damaged pack.
Tesla?s testing reproduced damage similar to that seen in the Tennessee incident, and also showed that a change in ride height strategy, which was implemented in Nov. 2013 via a telematic software update to prevent the SVs lowering at legal roadway speeds, mitigates the risk of battery compartment penetration when a three-ball hitch is struck.
