I'm using terms I don't understand, but here goes... There is a service bulletin for reducing rear camber in order to prevent the uneven rear tire wear that we have seen reported here and elsewhere. Lolachampcar is the TMC member who is an expert on this subject and is intricately familiar with the Model S suspension - you should PM him for some tips, or maybe he will post here.
Although I don't have uneven wear on my rear tires, I asked for the camber bolts to be installed and the camber reduced because most of the uneven wear has been linked to cars with air suspensions. The low setting causes camber to increase. With the reinstatement of the low mode, I thought it couldn't hurt to remove as much camber as possible as a preventive since the car will now be spending more time in low. Service center advised that camber bolt bulletin is really intended for 21" wheels, but they said there is no issue installing it on 19s and the results should be about the same.
