Not quite, but they’re getting close. $19B in assets and $3.6B in liabilities as of Q3, so ~15.3B in stockholder equity. Divided by 921M shares is just under $17/share.
Day's Range 16.56 - 17.54 52 Week Range 16.56 - 99.21
He is thinking the problem is that the cooling can't reach some parts of the pack, and it hot spots. Which would likely need a pack redesign. (It would seem that the software would have to be really bad for it to just be a software problem, but maybe they introduced a weird bug in a recent update.)The cooling fans aren’t even turning on at the correct time. Sounds to me like some software updates are in order if not a pack redesign.
On the Rivian forum, someone just posted that his vehicle cooling fans finally turned on after unplugging from a fast charging session. Sounds like the vehicle software isn’t anticipating cooling loads from fast charging, but instead reacting to measured pack heat, and it is too late at that point due to thermal inertia. Could be a bug, but I suspect just badly designed software in that the software engineer didn‘t know what they’re doing.He is thinking the problem is that the cooling can't reach some parts of the pack, and it hot spots. Which would likely need a pack redesign. (It would seem that the software would have to be really bad for it to just be a software problem, but maybe they introduced a weird bug in a recent update.)
I suppose it could be a flaw in his pack, but Branden complains about the same thing:
What if the problem is the stacked modules? The bottom modules are too close to the bottom of the pack and are cold, or colder than the top modules? Since there is only a cooling plate sandwiched between the top and bottom modules you have to wait for the bottom modules to warm up before you can start cooling or you would over-cool the bottom modules. (It might be impossible to maintain a similar temperature between top and bottom modules.)On the Rivian forum, someone just posted that his vehicle cooling fans finally turned on after unplugging from a fast charging session. Sounds like the vehicle software isn’t anticipating cooling loads from fast charging, but instead reacting to measured pack heat, and it is too late at that point due to thermal inertia. Could be a bug, but I suspect just badly designed software in that the software engineer didn‘t know what they’re doing.
Regardless, my point still stands. Cooling fans must be turned on in anticipation of heat loads, not in response to It. Fix that first, since it is software.What if the problem is the stacked modules? The bottom modules are too close to the bottom of the pack and are cold, or colder than the top modules? Since there is only a cooling plate sandwiched between the top and bottom modules you have to wait for the bottom modules to warm up before you can start cooling or you would over-cool the bottom modules. (It might be impossible to maintain a similar temperature between top and bottom modules.)
I don't recall if Munro showed any insulation between the pack bottom and the modules. But most non-stacked designs put the cooling plates between the bottom of the pack and the modules which is sort of a barrier from the outside temperature. (And where GM stacked modules they have separate cooling plates on the bottom of each module.)
Even if it results in the bottom modules being too cold to charge? (At those temperatures you might not need much fan usage to get enough cooling, but that also depends on wind speed.)Regardless, my point still stands. Cooling fans must be turned on in anticipation of heat loads, not in response to It. Fix that first, since it is software.
Oooooh. Sorry, I’m slow today. Yeah, considering this problem is showing up in winter, maybe you are right. Huh.What if the problem is the stacked modules? The bottom modules are too close to the bottom of the pack and are cold, or colder than the top modules? Since there is only a cooling plate sandwiched between the top and bottom modules you have to wait for the bottom modules to warm up before you can start cooling or you would over-cool the bottom modules. (It might be impossible to maintain a similar temperature between top and bottom modules.)
In fact I liked your reply so much I stole it and replied it to a tweet. SorryOooooh. Sorry, I’m slow today. Yeah, considering this problem is showing up in winter, maybe you are right. Huh.
Only Rivian knows the details, so it will be interesting to see how it plays out, but we might not see the results until next winter. (Though people have complained of problems when charging in the summer as well.)
Are there any other vehicles that double stack cylindrical cells? Lucid maybe?
Double stacked cylindrical cells with cooling running between the stacks is Rivian's patented battery differentiator.Are there any other vehicles that double stack cylindrical cells? Lucid maybe?
Tesla Semi. More than double stack.Are there any other vehicles that double stack cylindrical cells? Lucid maybe?
But we have no idea if the stacks in the Semi share a cooling plate like Rivian does or not. Most likely not, because Tesla uses a cooling ribbon between rows of cells in all the current packs we have seen.Tesla Semi. More than double stack.
Yeah I had always thought the cooling ribbon between cells was inefficient until Jordan of The Limiting Factor channel did his video and corrected me. Tesla appears to have excellent engineering when it comes to heat rejection. Their next gen charging cable with the conductors sitting in a liquid cooling bath is wild.But we have no idea if the stacks in the Semi share a cooling plate like Rivian does or not. Most likely not, because Tesla uses a cooling ribbon between rows of cells in all the current packs we have seen.
