Yes, that's what I thought you might be saying. Yes, it does seem that most AWD cars would have P-spec (rear) DU.
But, it's still speculation - you assume:
1) They actually didn't build *any* AWD vehicles before they built P vehicles. I think it's hard to guarantee this didn't happen. Maybe there is info out there to prove one way or the other, but I have no idea. I think we know P vehicles were delivered first?
Yup- they did highest profit cars first. Lots of reviews and deliveries of P models weeks before the first AWD deliveries. Seems unlikely they'd build AWDs and let them sit. Or that this mystical window of "non P" DUs would just happen to have wrapped up RIGHT in that tiny window as well.
2) They don't have a way to track which motors are tested to P-spec and which ones aren't.
Right- that's why the fact there's only 1 PN tells us they are
all P spec capable.
Assuming each DU has a serial number (I have no idea how/if they're marked), it doesn't seem inconceivable that they have an inventory program/tool that identifies which test program a DU was tested with when it is scanned prior to installation. Maybe they have no such thing, I have no idea.
Can you present any reason doing that would make any sense from a repair, parts ordering, or supply chain perspective- rather than using a different PN to denote a higher spec DU?
3) They have very strict rules for when they have to have a new part number.
Who is they? I've worked with quite a few major electronics OEMs and ODMs and it's not that hard at all to get another PN if there's a business reason to do so.
You're assuming a different test program with zero design change means a different part number for Tesla.
No, I'm not doing that at all.
I'm stating as a fact that replacement parts need to be correct, and that having a different PN for different spec parts is the industry standard way to do that, and nobody has suggested an alternative that isn't measurably inferior to it AND harder/more complicated to no apparent benefit.
I've been in places producing millions of units, where this is not the case. Just have to be careful...
I can't think of any factory or supply chain or repair ordering system I've ever worked with where they would ever make it possible to order a PN and get a part that doesn't meet required spec.
Which
would be possible in the AWD scenario you described where they put non-P motors in AWDs
after production Ps had already been built and both cars used the same DU part number.
All of the above may be true, but I'm speculating, and I think you're speculating as well. Which is fine!
I think this is the last time I'll talk about this, as there's no way to know right now!
I think the difference is you've offered no reason they'd go a much more dangerous and complex route, with no apparent benefit of any kind, versus just using another PN if there was ever a substantive performance difference.
Your explanation requires some kind of incredibly ideal timing where they magically got the rear DU perfect between RWD and P/AWD, and/or some wacky "secret second part number" system, using serial #s, because.... REASONS!
Mine simply requires MFG tolerances good enough that all motors are capable of P output. Which is hardly a stretch given how much praise every engineering tear-down of the Model 3 motor has seen.
Occam's razor. The simplest explanation is usually the right one.
There's only 1 rear DU for all LR model 3s, they're all P capable.
There's only 1 front DU for all model 3s period, they're al P capable.
No special timing needed, no special secret second PN using serial #s to encode testing, no nothing but good engineering.[/QUOTE]
