I got mine in too! Did it all by myself, hubby’s job is to hold the door.
I think it helps to have small fingers. Took me around 10mins.
Brake pad- get top corners on first, then use both index fingers to really stretch the sides out as far as you can, move downward as you keep stretching then stretch some more as you go over bottom corners.
Acceleration pad- get top right and bottom right corners to fit snug first, with one hand hold down right bottom corner as you use another hand to stretch and fit left top corner, now you have 3 corners on use one hand to hold all 3 corners then use other hand to stretch and fit the last bottom left corner.
Hope this helps
