PC__LoadLetter
Southbound at Pheasants Nest is now open. Ampol updated its entry on PlugShare a few minutes ago.Southbound at Pheasants Nest is well underway.
Northbound is a muddy pit.
Cool, if only they're not so expensiveSouthbound at Pheasants Nest is now open. Ampol updated its entry on PlugShare a few minutes ago.
It’s 9.That implies 9 cars can charge there simultaneously, which is not the case. Is it 3, 4 or 6?
Are you sure? I checked a couple of hours ago and again now. Both times, one of the Chademo plugs was being used, simultaneously with a CCS2 plug. Might be coincidence, but there aren’t that many Chademo vehicles around. More likely the use of that CCS2 plug took the Chademo offline. Or it’s just broken.It’s 9.
I admit, I could br wrong, but I’m basing it on the same hardware as installed in other places where they can all be used at once.Are you sure? I checked a couple of hours ago and again now. Both times, one of the Chademo plugs was being used, simultaneously with a CCS2 plug. Might be coincidence, but there aren’t that many Chademo vehicles around. More likely the use of that CCS2 plug took the Chademo offline. Or it’s just broken.
I can’t make out the parking layout but it could be they’ve intentionally limited simultaneous use if there are fewer spaces than cables?
That doesn't seem right. AFAIK the largest are currently:It doesn’t look like there are 9 marked parking spaces within reach of the cables… but if it’s true this site can do 9 cars at once, then that would make it the equal second largest DCFC in the country, which is a little bit extraordinary.
I always thought since supercharges only charge you for the energy actually put into the battery it is always better to go with supercharges if all else being equal (not sure how much a difference it makes though eg battery heating). But yes agreed a few cents per kWh probably doesn't make too much of a difference.If they can actually deliver 150kW (and possibly 300kW later) to Tesla's then $0.69/kWh isn't that bad.
Tesla Exeter down the road is $0.66/kWh
It's a great location for short range Leafs.
While it would, the fact that there are six parking spaces and six CCS connectors means that it doesn't matter how many Chademo connectors there are. It's not like the disparity is preventing CCS cars from charging since the number of spaces is the same as the total number of CCS connectors. (i.e. a Chademo car charging does not disadvantage you any more than if the car was CCS)It's a great location for short range Leafs.They may not do huge road trips, but this expands the city a bit for a city car. It will be very important to those that use it. One would have been enough though
Our 7year old gets occasional use when the days runaround exceeds the current range.My Gen 1 LEAF will be 9 years old soon… I have used the CHAdeMO port once!
