Any guesses on when the Model 3 hitch will be available in US.
Discussion in 'Model 3' started by opequan, May 14, 2019 at 8:14 AM.
Tags:
  1. opequan
    opequan New Member
    Tuesday
    Chicago
    Over the weekend I was about to order a Model 3 when I read that the hitch is available in the Europe. I'd really like this option, but I'm also racing the clock against the July 1 tax increase. I know there's always the after-market option, but if it's possible, I'd much prefer the manufacturer's hitch.
    Does anyone have any theories on how long it will be until we see this in the US? Have there been other country/continent first options like this in the past?
  2. Misterbee
    Misterbee Member
    Los Angeles
    I wouldn’t hope my breath. Tesla has bigger fish to fry, so a niche accessory for the 3 is probably pretty low on their list of things that will get the company in the black.
    My suggestion is to go for it. I put a Stealthitch on my M3. It is a great product, and I am having a blast.
  3. TMThree
    TMThree Member
    Tampa
    Whats the hit to your range with it? (when towing)
  4. devildogDMD
    devildogDMD Member
    Aftermarket hitch from etrailer. Cheaper than Tesla, easy to install, full range from my P3D is 165 miles at 75mph, expect to cut range about in half. From my research it seams to be the typical cut. In the picture it was 6 in the morning and the 8 slots were all empty. If it's a busy time I unhook the trailer.
  5. Zoomit
    Zoomit Active Member
    SoCal
    Your range is cut in half with your track trailer? That’s some serious drag penalty. How wide is it?
  6. Msjulie
    Msjulie Active Member
    San Fran Bay Area
  7. Runebane
    Runebane Member
    Visalia, CA
    When I pulled a trailer with my truck, my gas mileage took a similar hit. These things cause a lot of drag, now mine was a little bigger but then again so was the truck. My truck went from 24mpg to 15mpg when towing.
  8. Zoomit
    SoCal
    What causes a lot of drag? 4 wheels and a box? I’m talking about the trailer pictured not a cargo trailer.
  9. willow_hiller
    willow_hiller Member
    Maryland
    I imagine a not insubstantial amount of the range decrease would be caused by the friction of the trailer tires, in addition to any additional increase in air resistance.
  10. Watts_Up
    Watts_Up Member
    In a galaxy far, far away
    I love your teardrop trailer, it looks very kool!
    I have seen on YouTube several installations of a hitch on a model S or Model 3.
    It seems that the hitch would be used to install a bicycle carrier or so because they don't show any wiring.
    So, would you mind describing how you did the wiring?
    - Did you split the cables or use a wiring sensors kit? If so, where did you get the 12 V power from?
    - What kind of plug did you use to connect your trailer, and where did you attached the socket to your car?
    - What kind of lightning do you use inside the trailer?
    - Do you have a battery inside the trailer or do you tap the power from your car?
  11. Knightshade
    Knightshade Active Member
    NC
    Allegedly that's due to some EU regulation that basically forbids certain OEM parts from being added if they're not sold originally on the car
    Tesla releases Model 3 tow hitch for European markets
  12. Runebane
    Runebane Member
    Visalia, CA
    Even a tear drop trailer causes drag. The faster you go the more the drag. Yes, it's not quite the same as 4 wheels and a box, but there is still significant drag.
  13. mtndrew1
    mtndrew1 Member
    Gardena, CA
    #13 mtndrew1, May 16, 2019 at 9:58 AM
    I *really* want to do a hitch and tent trailer or a motorcycle trailer for track days but I’m worried about the insurance implications if there’s a collision while I’m towing with a vehicle not rated for such use.
    Have any of you addressed this or just hoping for the best?
  14. Zoomit
    SoCal
    I’m familiar with drag. A teardrop trailer is much larger than the trailer pictured. Drag is a function of the combined vehicle, specifically the tow vehicle wake influences the additional drag of the trailer, which is why I asked about the small trailer.
  15. devildogDMD
    devildogDMD Member
    It's more narrow than the car, you can't even see it with the side mirrors. I did an experiment to see if I could reduce drag but wasn't worth it. Only saved 4 wh/m. The manufacturer of the trailer, Leroy, is going to put it in an aero program to gather some more information.
  16. Uncle Paul
    Uncle Paul Active Member
    Canyon Lake,CA
    Flat sided trailers create a ton of drag at speed.
    while called tear drop trailers, they are anything but teardrop if they have flat sides.
    Older Airstream or Bolus tralilers had curved sides and generated remarkably less drag.
  17. devildogDMD
    devildogDMD Member
    So far our thought is that it would take a huge spoiler in order to make a difference due to the dirty air behind the 3.
  18. Zoomit
    SoCal
    That's a valiant effort with the cardboard! I'm not surprised it didn't change the drag much as it slightly increased the base area by squaring off more of the back. Still it was worth the try though.
    How many times have you towed it? Have you experienced the same range hit in different wind conditions? Any trailer that would otherwise be hiding in the tow vehicle wake is susceptible to cross winds increasing the drag.
    I'm not sure what you mean about a spoiler. Are you talking about putting a spoiler on the 3 to minimize the drag hit from the trailer?
  19. PittCaleb
    PittCaleb Member
    New Jersey
    I installed an eTrailer hitch on my Outback and need to do this to my Model 3 ASAP. I use it almost exclusively for a bike rack. I'l be moving my son off to college and taking a 1000 mile road trip to do so.
    Although it won't be as bad as a trailer, I'm sure it will be non-trivial. I suppose the first couple of super charger stops I should stop sooner after I realize what my true range will be.
  20. devildogDMD
    devildogDMD Member
    Several times, once from DC to NJ and once from DC to Summit Point. Also twice for the test. It did better going to Summit Point because there is a lot of time off the highway. DC to NJ use was 400, DC to SP was 375.
    Bigger spoiler on the model 3 to push the air up and away from the trailer. My goal with the cardboard was to keep the air off of the box. I also closed off the floor to keep air from coming up from underneath.
    If anyone has any other ideas I'm game to try it.
