Anyone Still Experiencing Charge Current Limiting (40A->30A)?
Discussion in 'Model S: Battery & Charging' started by DavidM, Dec 29, 2014.
  1. DavidM
    DavidM P2624, Delivered
    Florida
    Since the 5.8.4 software update, many Model S owners began to experience charging sessions where charging was randomly reduced from 40A to 30A. When it happens, there is usually a message on the dashboard that says "charging problems". The impact of this change is slower, and unpredictable refueling sessions. Personally, I have owned my Model S for 2 years. For a full year before the software change, I could charge at home (at 40A) unimpeded. Since the change, the software limits my charging to 30A (in most cases).
    The power utility has checked the install and the transformer. Tesla has checked the install. Electricians have checked the install. Everything is within standard residential tolerances (but perhaps not within the new Tesla tolerances). Lots of head scratching. Tesla won't disclose the old (or new) tolerance levels to the power utility, which makes it difficult to troubleshoot the problem. I am using the Universal Mobile Connector (with the revised adapter).
    Is anyone else still having this issue with the car randomly backing off to 30A while charging at home? If so, are you using the UMC cable, or the beefier Wall Connector?
  2. studiojon
    studiojon Member
    Redondo Beach
    I have the same issue using the Tesla wall charger permanently installed in my garage.
  3. shady
    shady Member
    Morgan Hill, California
    I would say it happens to me about once a month
  4. scaesare
    scaesare Well-Known Member
    NoVA
    I get it every few weeks as well.
    I've looked at the voltage sag when it happens, and I can't find any pattern to it.
    It's a bummer, as in the winter I schedule my charges so they finish shortly before I leave in the morning, and occasionally I'l lend up with less range than I'd like.
  5. Forty Creek
    Forty Creek Member
    Carlisle, Ontario
    I have had the problem with my HPWC ever since the software update. Charge rate drops from 79 amps to 59 sometimes immediately and sometimes after 10 minutes or so of charging. Occasionally the charge rate holds through the entire charging session. It has nothing to do with what else is drawing power in my home. It happens even when I do a scheduled charge starting at 2:00 AM. In my case the voltage displayed in the car drops from around 238 to 221 as the amps ramp up. It seems very likely that the software detects this drop and lowers the charge rate. I suspect that your power utility will need to do their testing under load otherwise, everything 'looks' fine. Tesla was pro-active and offered to send out one of their electricians to look my problem but for a variety of reasons I haven't taken them up on it. I will in the next week or so, once the holidays are over.
  6. qwk
    qwk Model S P2681
    What firmware versions are you guys on? 5.9 and later let's you toggle the amperage up after the software dials it back.
  7. Forty Creek
    Forty Creek Member
    Carlisle, Ontario
    I have the latest update. No, you can't dial the amperage back up during a charging session where it has been reduced. You have to stop charging, then start charging again in order to get back to the pilot amperage (80 amps in my situation).
  8. Cerie
    Cerie Member
    Connecticut
    It happened to me once before I started using scheduled charging. I think it was because I had too many other high voltage demanding things running at the same time (laundry machine, dishwasher, central vac) but since I moved scheduled charging to begin at midnight, it hasn't happened since. Try charging it in the middle of the night when nothing else is going on.
  9. apacheguy
    apacheguy S Sig #255
    So Cal
    Happens periodically. Annoying that it requires manual intervention to reset.
  10. DavidM
    Florida
    I suspect the changes that Tesla made to the software with 5.8.4 were overly aggressive, and as such, it detects what it thinks is a circuit problem, when no such problem exists. I've brought this up with Tesla Service several times, over an 8 month period. Both with my local service center, as well as with headquarters in California. At this point, California simply routes the issue back to my local service center. Now, they are silent on the whole issue. I have not received any indication that anyone is looking into the issue. Dealing with this sort of thing is why I have become sour on Microsoft over the years. They download updates to my computer. Many of the updates make my computer better and safer, but there is always one item that gets screwed up in the process. Something that worked perfectly fine before, and is now partially broken.
    It's obvious that there are many Model S customers who are experiencing the same issue (to varying degrees).
  11. sublimaze1
    sublimaze1 8Dec2012 / Leeroy Jenkins
    Basin City, TX
    I have noticed this as well.
    I can get 40A most of the times, then it will drop to 30 and stay there unless I manually reset to 40.
    I have a feeling it has to do with the adapter not fitting 100% into the car and when that happens, the feedback to the UMC (or wall charger) module detects it and steps it down. Not a big deal, as I charge every night and it doesn't get low. But when I do come in with less than 30-40 miles on the range, I make sure that it seats well and that I dial it up to 40.
    Small price to pay - FWIW.
  12. apacheguy
    So Cal
    Well at least you can uninstall a Windows Update or better yet, restore your OS to an earlier date.
  13. DavidM
    Florida
    I hadn't thought about that. But that could be fixed with a better connector, or a software tweak. Neither has been attempted, or even suggested by Tesla. A few times I've returned home after a long trip with minimal range. I needed to run some additional errands before dinner, and would have appreciated the ability to charge at 40A (28 mi/hr), instead of 30A (21 mi/hr). But I agree that in most cases, charging at 30A overnight is adequate. It just bugs me to have paid for 40A, and now receive 30A. This after having 40A capability for over one year.
  14. Forty Creek
    Forty Creek Member
    Carlisle, Ontario
    Just as a data point, I have had my HPWC replaced AND the port on my car replaced. Still experience the step down in charge rate nearly every time.
  15. dan-l
    dan-l Member
    Tampa, FL
    If you are near the Tampa Bay region, I'd be more than happy to swap UMCs with you for a week to see if that helps your situation.
  16. DavidM
    Florida
    Thanks a lot Dan! But in light of "Forty Creek's" comment, I doubt there is an issue with the UMC. Tesla gave me a loaner car several months ago, and I experienced the current reduction on that car as well. With so many owners experiencing this problem, I'm convinced that the software parameters are just too aggressive for standard residential electrical service.
  17. scaesare
    NoVA
    I ended up with a replaced HPWC as well... still no deal... so I don't think it's the HPWC.
    Also supporting that conclusion is that according to Visible Tesla (and the dash displays when I've caught it), is that the HPWC is correctly reporting a pilot current of 40A:
  18. smsprague
    smsprague Member
    Prescott, AZ
    I have had this issue twice in my 6 months of ownership. Drop from 40 amps to 30 amps after about a minute. Both times Tesla replaced the master charger. Last time I was told I had a new design. Has been charging at 40 amps for last 6 weeks so I am hopeful
  19. kennybobby
    kennybobby Member
    Heart o' Dixie
    So many numbers, and such precision of battery current to 0.1 amps, yet curiously absent is one of the most important
    values--battery voltage...? And other important factors: pack and charger internal temperatures.
    i would think that most EV chargers for lithium packs have conditions to limit power based upon simple electrical and thermal measurements.
  20. scaesare
    NoVA
    I don't believe battery voltage is something Tesla supplies via the API. But the chargers ramp the voltage up to whatever the battery requires, and then limit the current based on what the battery profile requires. SO not seeing battery voltage shouldn't be a problem.
    As for pack temp... it's understood that charging at 1/8C or so shouldn't put any real thermal stress on the battery that would likely limit it.. and if so, the cooling system kicks in. In any case, this is in my garage where it's 40-ish degrees, so there's no real thermal issue here at the moment...
