fasteddie7
I might have found a bug. While on autopilot several times the last few days I get the "accelerator pressed, cruise will not brake" message pop up while the accelerator is not pressed.
2016.5 AP1 75d 36.2.1FE7;
Could you state your cars build and what version you are on? Also, suggest file a bug report if you have not already....
Could be worse, at least it is not trying to make you one with a K wall...
Happened to me also once recently, but I am still on 32.12.7.I might have found a bug. While on autopilot several times the last few days I get the "accelerator pressed, cruise will not brake" message pop up while the accelerator is not pressed.
1. Yes, my browser works. I don't use Waze for Tesla. Actually my browser is a bit quicker to load now. That's not really saying much though, because it still sucks.So:
I've left my 2015 P85D on v9 because I use Waze for Tesla all the time to stay ticket free.
- Your browser works... and remains working? (including Waze for Tesla)
- You see the release notes?
- Can access the owner's manual?
That just seems like such a one-off scenario. When you're in reverse, I don't even know why changing HVAC options would be on your mind.When you're backing up, if you go into the HVAC controls, the backup camera goes away.
Because if your back window needs to be defrosted. It's happened a couple times. I just think there's no reason why it should completely disappearThat just seems like such a one-off scenario. When you're in reverse, I don't even know why changing HVAC options would be on your mind.
Only if you like rolling dice on range and charge rate, and have, or want Spotify. In my case it worked out ok...I have a 2016 Model S 70. My software has been 2019.28.3.1 f9e95acd for a while. Should I have another update by now? If so, is there anyway to initiate it?
If you touch any of the popup controls this happens. Serious flaw. Been this way since the 9.x. I reported it to Tesla back in January. This was their response at the time:if you go into the HVAC controls, the backup camera goes away.
Thank you for writing in about the reverse camera. This is something that our techs will look into. We do want our customers to be safe and the back up camera is important for that.
About as safe as their new armored glassIf you touch any of the popup controls this happens. Serious flaw. Been this way since the 9.x. I reported it to Tesla back in January. This was their response at the time:
I see what you mean, while in reverse, the HVAC controls wipe out the backup camera, which does not return. You can close the HVAC screen and even though you are still in reverse, the back up camera will not return till you re select reverseIt looks like they finally fixed the lag on push to talk. It's worked every time I use it. The browser is somewhat better but doesn't work well with tesla waze.
I have found a bug that has probably been around a while. When you're backing up, if you go into the HVAC controls, the backup camera goes away. There's no reason they couldn't just shift the screen up a bit. Should I be adjusting the temps while backing up? Probably not but it does happen every now and again. Also, to be clear, if I just adjust the temps and not go to defrost etc, the camera does stay.
Yup, the camera really should override any other selections as it's technically a safety feature.I see what you mean, while in reverse, the HVAC controls wipe out the backup camera, which does not return. You can close the HVAC screen and even though you are still in reverse, the back up camera will not return till you re select reverse
Still waiting patiently for 2019.36.2 update for our 2015 Tesla S. I don't know why they are so slow rolling out the new software to the older cars. I have set the software download to "advanced" and have good WiFi connection in the garage.
Any suggestions on what I can do to get the new software update?
