I will apply rotational force to the wheel almost enough to break autopilot then less then 10 seconds later it will tell me to apply slight turning force to steering wheel. It makes it pointless to use autopilot.
2020 model 3 standard range with less than 25k miles
Are you sure this is correct? I have a just-minted 2022 Model 3 LR and autopilot nags every 10 seconds regardless of my attention.they are using the internal camera to watch for attention now. If you look at your phone or stare away from road for more than 7 or 8 seconds it’ll beep at you. I’m guessing it’s your recording device that’s triggering the message. If you keep your eyes on the road, the gap between nags should be >30 seconds
I have a 2022 MYP and if im wearing my polarized sun glasses its every 20 seconds on the dot. if im not wearing glasses, its longer. it does track eye movement. you're looking in a direction other than your windshield, it will nag. as it should.Are you sure this is correct? I have a just-minted 2022 Model 3 LR and autopilot nags every 10 seconds regardless of my attention.
I've found a similar thing to you, no issue with nags because I'm holding the wheel and applying torque.Nags due to lack of torque on the steering wheel will not give an audible 2-beep chime at the onset. Those are due to lack of confidence by the AP system. If that's happening constantly (and not just at tricky scenarios on the road), something is wrong and warrants a service appt to get it checked out.
Nags due to inattentiveness (eyes not front, using phone, etc) will result in 2-beep chime nags, but the message on screen should also reflect that. I forget the actual wording, but it's more "pay attention" than "keep your hands on the wheel". These nags also shouldn't be very sensitive. I can look away (out the side window) for almost 10 seconds before I get a pay attention nag.
In my car, the torque required to suppress nags in FSD beta mode (local streets) is much less than what's required with AP/NoA on the highway. I very rarely get no-torque nags while in FSD beta mode. I'm hoping the lower torque setting will apply to highway once we have single stack. The idea of requiring torque to prove attentiveness was always annoying to me. Reducing the torque force required is still not ideal but very welcome.
yeah, the 'pay attention' nag isn't very accurate. I've gotten it multiple times while looking straight ahead.I've been in the beta program for months now, and this week, I've gotten two strikes during highway driving. I can't get rid of the blue flashing warnings, which lead to red warnings without putting enough torque on the wheel to pop it out of autopilot. I was putting the entire weight of my arm plus bicep engagement on the wheel, but still no luck. The safety nag is making me a less safe driver.I've also gotten the audible "pay attention" maybe 10 sec after engaging autopilot without any blue flashes. I'm wondering if there's something wrong with the torque sensor. Extremely frustrating...wonder if it's time for a service appt.
I ended up turning FSD beta off for highway driving. My autopilot driving over the last few days without it on has been fine, which makes me believe it's not the torque sensor...perhaps a tolerance stack-up problem with FSD beta. Good idea on the reset. I may give that a shot and see if it starts to behave.yeah, the 'pay attention' nag isn't very accurate. I've gotten it multiple times while looking straight ahead.
You an also tap the right stalk down or move either of the scroll wheels to dismiss the blue screen nag. Were you having problems with he torque sensor before? Maybe try doing a reset to see if that helps. You can also turn off FSD beta while you're troubleshooting and to see if that changes the behavior.
Only users on FSD Beta get these "pay attention to the road" nags. I own two M3s, one with FSD Beta and the other with FSD but not beta. I only get the attention nags on beta. As soon as beta rolls out more widely, you'll get them soon enough.I've never gotten a message initiated by the camera to pay attention no matter how long I look away. (Model Y)
Yesterday as a test on the highway (with a passenger to be sure I was safe) I looked completely away for over a minute. No alert.
Then I tried using the display for over a minute with the same results.
Nags from the steering wheel certainly do work but infrequently as I've found the sweet spots, at least in my car, for holding the steering wheel.
Unfortunately, the feature has been necessitated by multiple idiots doing what they do best and being irresponsible. Even with the current safeguards, people still criticize them as being too easy to defeat.I really detest this feature and have avoided using Autopilot for this reason. Half the time I'll inadvertently disengage Autopilot and then I wonder why the car starts heading towards the ditch. It's a worse solution than the problem.
Yeah, on the rare occasions that I use it, I now just move the volume wheel up and down. Still annoying though. I hear you about the idiots.Unfortunately, the feature has been necessitated by multiple idiots doing what they do best and being irresponsible. Even with the current safeguards, people still criticize them as being too easy to defeat.
You don’t have to move the steering wheel, you can also move one of the scroll wheels or tap the right stalk down. Either way, the system will give a 2 toned beep/chime when it disengages and the steering wheel will suddenly give way and stop resisting your force. It’s not subtle.
I am a FSD beta testa. Only gotten 1 message about 2 months ago.Only users on FSD Beta get these "pay attention to the road" nags. I own two M3s, one with FSD Beta and the other with FSD but not beta. I only get the attention nags on beta. As soon as beta rolls out more widely, you'll get them soon enough.
