This does not sound right at all.
The plus 15 shown is the number of miles that have been added to the range on the charge so far, and doesn't have anything to do with a bonus for the chargers. I don't believe that there is a difference in charge rates on the car when charging at 40A 240V (or less) between a single charger and dual chargers.
As I've had a lot of time and opportunity to play with charging at various currents and voltages using either a single or dual chargers and listening to the relays while watching the current draw, here is what I see:
Charging sequence starts up and if the current is set to 40A or less then only one charger is used, and current ramps up. If the current is above 40A, relays are switched, and then charging current ramps up to the requested rate.
Peter
Peter
Looks like there is one more reason for the second charger!
Cross post from:http://www.teslamotorsclub.com/showthread.php/10398-Model-S-Technical-Mechanical-Issues/page104
