I don't think anyone is asking for Qobuz to be added to Tesla Knightshade. At least that is not my understanding.
It is not mine- based on:
Audio companies are falling all over each other putting Qobuz on their systems, companies much smaller than Tesla. I don't think the technical expertise needed is all that great. I can put it on a lowly Raspberry Pi.
and
Qobuz has 70 million tracks to choose from according to their website...Once you have access to it you don't want to be bothered with anything else....
As both Gnomen, rjpjnk and myself have said, this limitation in the Tesla is archaic.
Sure sounds like he's asking for it to be added, pointing out how other companies (not named) are "falling all over each other" to do so and how "easy" it should be and how "archaic" teslas lack of it is.
Frankly, this is just obtuse. The whole argument you are providing is wrong-headed.
Dude- YOU are the one who started the "OMG COPYING TO USB TAKES TOO LONG" argument.
Don't be mad when someone points out how silly that objection is because nobody sits there staring at it waiting.
For 10 years most manufacturers have made it possible for you to listen to whatever you want
And for 100 years they built stinky gasoline cars.
Teslas
entire interface on the 3/Y is built around one large display and controls, and reports, every bit of info to and from the car.
They have zero interest in turning that display over to 3rd parties , and a lot of good reasons that's true.
So your choices are:
Stream "whatever you want" over BT using Teslas built-in interface for doing so
or
Use the streaming services built in
or
Play locally from a USB storage source using the built in interface
They've added new built in streaming sources- and plan to add more.
Including a high bitrate one (Tidal).
If none of that is sufficient to not ruin the car for you, I'm sure a Ford dealer will be happy to sell you a marked up Mach E with android auto and carplay and whatever
If Tesla added a simple analog input anyone could play back their own source from a phone at a much higher quality.
Most phones no longer
have an analog port so once again you're asking them to add a niche solution (and asking them to add hardware to do it).
Another option would be if they provided a high speed digital input via USB port.
FWIW I DO think it's goofy you can't play LOCAL music off the phone just as you would off a 'dumb' USB storage device-- but that doesn't seem like it'd make the folks upset here any happier anyway.
Adding streaming this way is a whole other can of worms as it's no longer a case of the built-in Tesla player interacting with "storage" but requires interacting with 3rd party apps on your phone
