For sure there are lots of good options. The only empirical test that I have ever seen with a spectral analyzer showed that a lot of materials are very close. I think that result or at least a link to the test was posted on this section of the Forum many pages ago if I'm not mistaken.What product would you recommend to use for sound deadening?
I'm using the top rated product on Amazon, Noico 80. It's so easy to use and I think it's as effective as anything else at that thickness that I wouldn't think of switching to something else. Sticks like crazy. The aluminum is thin enough that you don't generally get cut fingers from working with it. Plus it's got a quilted top layer that's the aluminum foil essentially that allows you to see how completely you've pressed it down. The Quilted design disappears as the material gets more and more tightly compressed on whatever it's attached to. This makes it really easy to see where you need to work with your roller or other application tool . I use two rollers of different sizes and a large plastic spoon to get compression on the material. At this point I wouldn't use anything else. In my opinion it deserves its top rated status on Amazon.
