Yes, I meant outer door metal (outer skin of door). Door Cavity behind the speaker acts as speaker cabinet, hence it is important to reinforce that. Yes to do that, you need to at least remove speaker and apply dynamat directly behind at minimum. Because of large surface area without many creases outer door skin need more reinforcement compared to inner. Also, if space permits something like wave breaker kit (Hushmat Wave Breaker Kit) is beneficial.
Last two cars I did, I removed complete inner panels, not just speakers and applied several strips of dynamat to outer door skin. It makes substantial difference on how door feels(knock test also), and helps reduce low frequency rumble transfer from outside.
I did not open my Model 3 yet, but based on images I saw, it should not be big effort to remove the front door speaker and apply Dynamat behind it. Normally sealants are very flexible and reusable, and worst case you can use outdoor silicone sealant to seal.
Don't know if I feel differently now about the amount work .. Only recent work I did on car speakers is, a month ago, I had to replace factory JBL mid/woofers on friend's Prius with JBL premium sound system as those failed. Replace both with 3 Ohm Rockford 60W mids. Built new harness so that factory harness need not be cut, and also needed to modify mounting ring to fit those. Took couple of hours though.
Thanks for sharing your work, photos and thoughts! Generally I am too lazy/not inclined to take photos while I work, if I start, I just want to finish it off first!!
Nice catch on that product. Will install once I have a replacement speaker from BadDesign that is straight pop in. Not a lot of margin in chasing it right now, as I will just have to open up that space later with the replacement driver. Thanks!
