Less things to fail also.
One thing I've noticed with the soft close though, is there an emergency release cable? How do you get in the frunk should the soft closing motor fails?
I have 1Tb SSD and was going to replace USB dongle coming with the car but then read another thread on this forum 128Gb is more then enouth for camera footage and I am not going to store my milm or music collection on it so no reason to replace.Its 128g
I know one person who already was in this situation. Its me. Few things to know:One thing I've noticed with the soft close though, is there an emergency release cable? How do you get in the frunk should the soft closing motor fails?
Correct, it just pulls it down and the normal latch holds itI know one person who already was in this situation. Its me. Few things to know:
- soft closing motor not holding the frunk, just pulling it down so it will be picked up by the original car lock and then releasing it after.
- I did not realised it and thought it is actually holding the funk and managed to get inside the frunk space from the right front wheel and cut the power cable powering the soft closing motor. After that I found it was not holding the frunk. So basically I can't imagine situation it will lock the frunk.
The Hansshow kit has a release cable for the factory latch and what looks like another on the motor.One thing I've noticed with the soft close though, is there an emergency release cable? How do you get in the frunk should the soft closing motor fails?
They look awesome man, great little upgrade!Finally got around to installing my "performance" pedals. Cut my thumb bled a bit in the process haha but got it done after about 15-20mins. Using the hair dryer, the brake pedal took 2 min, but the acclerator was a b!ch to get it to sit right . Worth it tho they look great!
No hub but yes the trays are perfect@dronus did you end up finding a USB HUB that worked well with our M3H?
Also are the center console organisers you ended up settling on the ones that are on the first page or did they not end up fitting the Highland?
the 5 pin plug but connected just to 3 - Earth ,Neutral and one of (L1,L2,L3) for line. most likely L1 but can be any of those.for 3 phase its 100% 5 pin. I am confused how ppl using it with single phase.
I tried it and after 5 mins just somehow squeezed the original one back and put these in the glovebox and forgot about it until I saw this message. Think I should take my hot air station next time to avoid hurting my fingersFinally got around to installing my "performance" pedals. Cut my thumb bled a bit in the process haha but got it done after about 15-20mins. Using the hair dryer, the brake pedal took 2 min, but the acclerator was a b!ch to get it to sit right . Worth it tho they look great!
It won't make a lot of difference as 32A 3 core cabling which gives you 7kw is equally costlier or more and harder to route than 16a 5 core cable which gives you 11kw with the added benefit that it will keep the grid balance. And you can get OEM 11kw/22kw 3-phase chargers at around ~$300-$400. So all together it makes more sense to go with 3-phase if your house is 3-phase.wow that looks great! wait is that a UMC? where did you get that holder for it? mine just hangs on the hanger
Yeah probably why he quote $1000 since he has to run 20m of cable up and across the house (double storey)
but wonder if I could get away with a single phase 32A 3 pin socket? Even if my house is a 3 phase, can I just get him to install a single phase? or that wouldnt work?
They are good ones, low profile and won't damage the paintwork like the other ones that wrap around.
The tesla wall charger also has a nice integration with the tesla app, if that is of interest to anyoneIt won't make a lot of difference as 32A 3 core cabling which gives you 7kw is equally costlier or more and harder to route than 16a 5 core cable which gives you 11kw with the added benefit that it will keep the grid balance. And you can get OEM 11kw/22kw 3-phase chargers at around ~$300-$400. So all together it makes more sense to go with 3-phase if your house is 3-phase.
But then if you are 100% mind set that you are only going to use 7kw single phase for all your life then there is no point in getting 32A 5-wire three phase cabling routed from 20m away.
Things to consider:
1. CCS2 charging is open protocol and you are not getting any magic sauce by sticking to tesla chargers except the auto charging port opening by pressing button on the charging plug.
2. These AC chargers are just glorified switches with some signaling. Unlike a mobile or laptop charger, there is no power conversion happening in these AC single phase or three phase chargers. Whatever is coming from the grid is passed over to the car with a simple signal which tells the car how much maximum to draw. That's all.
3. Most of these third party chargers are manufactured by some well reputed OEMs like Mida and are dissected and studied many times and are found to be of excellent quality.
Yes, you will miss the tesla magic charge door open button. But other then that if you just want reliable charging at affordable price you have lot of options.
