2019 S, EAP. Out this morning to test the auto parking. Conducted several parallel parking's and system worked great. Seems that it gets really close, but it maneuvered flawlessly. So, we tried parking perpendicular. I found a couple spots, waited for the "P" and put in reverse, hit the "start" and it backed in, pulled forward and then it continued to back into the spot. Flawless, but yet seemed close enough that you want to hit the brakes and take over. Pulling into the driveway, I always back in so rolled past the garage area and I get a " P ", ok, I'll try it. Put in reverse, hit the start screen icon and it starts backing into the garage! This time it wanted to back into the side of the garage and I had to stop prior to ramming into the side. That didn't work. So, I went out, turned around and tried it again, but the same thing happened. It wanted to back into the side of the garage. Laid tape down marking the area and that didn't help either. More than likely, since it is a two/two car garage the area was to big to center itself and tried to get as close to the side as possible. I don't know for sure, anyone else tried this?
