Autocross- SCCA EV-X Class vs. SS
So the new M3P is looking like it will have a bit more power (maybe only above 45 MPH) and likely some sort of upgraded shock technology, possibly adaptive. May also have wider rear tires.
Any guesses on how long it will take the SEB to put this back in SS? I bet it's before one even runs at an event.
Thankfully for those of us with EV-X builds of the pre-highland, it's not likely to just be dominant in EV-X once you are running huge tires and coilovers.
Power isn't the issue of the M3P in AutoX terms. Without some help, its almost an issue of mo-power-mo-problems.
IMO, a big issue/limitation is the power cut with steering angle Tesla has in the programming to tolerate the lack of rear LSD. I kind of want to find a way to intercept the steering angle sensor to modify it and prevent that steering angle power reduction to modulate myself with a calibrated foot.
But for a street car to have more power over 45, that would be much more fun.
First event on the RE71RS's yesterday. Holy *sugar*, this car has never felt this good, way more predictable than the RT660's. Was back in the fight for FTD for the first time in over a year, ran a 27.256 but whacked a cone. It wouldn't have mattered anyway as Jay went out and laid down a flyer on his last run, fresh A7's on a GT3 will do that.
Discovered that Tesla changed the way track mode telemetry is recorded so none of the data I recorded yesterday is usable for my normal video overlays :(. Going to have to adjust my workflow next event to get usable data.
What's the difference?
In the past I would drop the start/finish line pin out around where the finish was, hit start, do my run and hit stop. Most of the run would be recorded as lap 0 and it may flip to lap 1 before my run was over depending on where the pin was, but it didn't matter as I didn't care about the lap.
Here is what an old log looks like when it flips to lap 1.
Here's what a log looks like now.... Do you see the problem?
Elapsed time doesn't start recording now until a lap actually starts. And the sample rate isn't consistent enough that I can just make it up to save the data from this past weekend.
Lesson learned for next time.
So, an AS Model3 did pretty well at the Texas tour. Thoughts?
Not to knock anyone, but that driver has run multiple other national tours and has never placed well when there is strong competition.
In 2023 in Vegas they ran 1s slower than AS and 3.5 seconds off at Lincoln. In Vegas the top AS car was an Elise, so that was not even a max competitive AS car.
Texas just isn't a competitive tour- they didn't even have a single SS car! The one EV-X car ran 4 seconds faster than the AS M3P, while at competitive national tours, EV-X tends to run just about 0.5 seconds faster than competitive AS cars, so I have to believe a good AS driver in a Cayman or Z06 would have completely dominated AS.
This upcoming tour at Crows should be a bit better. Good drivers in AS and Navid will be a good driver to watch to see how the car does in class, don't know about the other 2.
Dallas, with all his custom SSB suspension bits, will be in XA with his wife. I'll be in there too, since running EVX in a class of 1 isn't fun.
Also, if your car is Intel Atom based, you're going to find at some point it will disengage from Track Mode unexpectedly during a run.
When this happens, could you please report it as a service request in the app including a timestamp when it happened.
The more bug reports the greater the chance it'll get fixed.
My thread about this bug is here: Multiple M3Ps dropping out of Track Mode for no reason
Reactions: Lindenwood
I'm gonna quote this reply in this topic, cause it's more relevant here.
If it is, its not by much. All the kits for TM3s are super soft and even with my current spring rates (800/1200) theres quite a bit of roll. Thats only 2.1hz/2.2hz. And tires alone need 1.5-2deg on their own.
I seem to recall calculations just a few pages ago in this topic that suggested 900+ front rate just to get to 2hz.
Did you perhaps re-measure the motion ratios or unsprung weights more accurately?
Thanks
Its been a couple years since I measured and I seem to recall getting 0.68 front but MPP or UP said 0.72 so I averaged it. Def not 0.6 up front though. I should have done a finer resolution measuring last time I had it apart but I didnt... 😅
Idk, I did measure geometric motion ratios crudely around stock ride height and got 0.63/0.6 front/rear. Those numbers roughly matched what I got from lower arm hole ratios and coilover inclination angles.
MPP/RW claims I've seen are generally about the spring perch offset <-> amount of lowering correspondence, and those are around 0.7-0.8. They claim bushings have a significant impact on the amount of lowering. I can imagine that OEM front swaybar, flca, and compliance link bushings indeed do matter unless replaced. But in the rear every link can/should be loosened and re-tightened at new ride height. So, I don't understand their lowering claims.
Dynamically, rubber bushings do matter of course and act like extra springs. Not sure how to account for those in the desired spring rate calculations so that the overall suspension has ~2 Hz natural frequency.
I imagine the ultimate EVX car, however, has all the bushings converted to bearings, and OEM front swaybar bonded bushings are likely gone as well.
So, I think one would be back to geometric motion ratios.
Points event 2 yesterday... ended up 4/123 raw and 3/123 pax. Still loving these RE71RS's
I dropped a pin in the lot that I would trip via track mode before my run but I still have no usable data for some reason. It recorded like 3-4 laps per run. I guess maybe since we exited on the other side of the lot and I manually stopped track mode recording it threw out that "lap"? idk, these changes suck.
