no idea, really. on ap2 signal is NOT split. it goes into ap2.0 and is then mirrored to the cid.
For clarification what's the difference between mirrored, and split for this signal?
To me mirroring is recreating the digital video signal versus just splitting it. But, it wouldn't be able to recreate the video signal if the incoming video stream was stopped/corrupted. So if it was mirrored this way you would never have a case of the CID working when the AP2 wasn't.
The kind of signal isn't like an analog video where you easily split it. Instead you receive the signal using a deserializer that has the capability of replicating the signal on a second channel. Something like the TI DS90UB954 deserializer, and then something else to serialize the second channel in order to send it to the CID.
On AP2.5 what does the hardware splitter do exactly? On your post I'm assuming the signal from the backup camera gets split so it goes to the Drive computer, and the CID. But, there is conflicting information that says there is redundant wiring on AP 2.5 so the backup camera actually goes to the drive computer twice and that's what the splitter is used for. Where one signal goes to the first Parker SoC, and the second signal goes to the second Parker SoC chip.
Post 13 of this link is where I'm getting that info.
v9.0 Dashcam - why only 2.5?
In that post it says AP2 has two autopilot engines. I wouldn't really call it that as the Parker SoC isn't the entire autopilot engine. But, the Parker has the ISP's for the cameras.
I'm confused about why the backup camera would go to both, and not having ALL the cameras go to both.
I should either find a diagram of how the cameras are connected in AP2.5 or to create my own. I have a Model 3, and so that's the only one applicable to me.
