chipmunk
To more directly answer your question, yes you are recommended to regularly charge the car up to a maximum of 90%. The charge screen of Model S looks like below.
The best thing about the Model S is you know exactly how much range you have remaining. The calculation is very accurate, enough to run the range down to zero (though that is not recommended). I have arrived at charging destinations in the single digits many times before, especially back in the days before there were any superchargers on the east coast (man have things improved!)
The biggest impact on consumption is speed.
And to the airplane/airport analogy, fine and good, only usually the airports are a little over 100 miles apart. Even if Tesla announced a "300" mile range for the 3, I am sure half the people buying one will complain that these are only EPA miles, not "realistic driving" miles.
I have been driving a Volt for the last 4 years and having that ICE for a backup has kept me from any range anxiety to speak of. With the Model 3 however I am interested in seeing how pure electric owners handle it.
I plan on approaching my long drives (more than 1 charge distance) the same way I used to handle my IFR flights back when I flew little airplanes. In an airplane you are required to plan your trip so that you land with no less then 45 minutes of fuel reserves on board (that may have changed now). This is of course in place to keep people from running out of gas which at 10,000 feet can be a rather pucker inducing experience! My thought is to plan trips to arrive with a buffer of say 30 miles of charge left. The big question is how much range you can actually expect from the stated range. On my Volt I see on the average about a 20% reduction in the full charge stated range due to weather, driving style, what have you. In the cold months running the heater that can be as much as 40%.
If that holds true then I am hoping for a 300 mile battery option so that I can expect about a 240 mile actual range leaving a 30 mile buffer so I could plan for a 210 mile trip between charging stations without feeling that "will I make it?" feeling.
Am I over thinking this? Have other Model S or X owners seen these types of numbers with actual range vs. stated range? How do current Tesla owners handle the long trips to avoid the stress of not knowing uyou are going to reach your destination?
Thanks for any feedback you may have.
Dan
Range anxiety is something you have before you get an EV. It's fear of the unknown. Once you have it and know how far you can go, everything is fine. I drove 73k miles in less than 2 years with my Model S. Many long road trips. Never ran out of juice. Especially now with the trip planner in the car it's so easy.
On a full charge, driving 60 mph in good weather I would hope to do better than EPA range.
Dan
Actively watching range and slowing down, is Range Anxiety.
Its good to see that you all manage it well.
It is harder to plan long trips w/ 200mi range vs 400mi range.
Just one thing that I recently found on a reddit thread that I wasn't aware of -
The recommended thing to do is only charge your battery to 80-85% (and that tesla cars have pre-set settings on how much to charge a battery and that's around what they're set to by default. This helps maintain capacity over time.
I had no idea, maybe some of the S and X owners can step in and confirm this, but that sort of reduces the actual range from 200 to 160 for everyday charging driving. And if you want to leave yourself a buffer than the real range maybe 130-140 Makes me think twice about just sticking with the base battery - especially since I heard upgrading the battery is the #1 thing you could do (historically) to bump you up on the production list.
