Back speakers and Sub not working.
Nathanael
55
81
Toronto
Yes I have contacted service - just posting to see if anyone else has come across this problem.
When I picked up my Model 3, only the front speakers were working. Someone at Tesla did a hard reset, and it seemed to temporarily fix the problem. The next day same thing happened, hard reset work. Then again, and again, until now the hard reset wont even bring speakers back.
Anyone else have this problem? I picked up last week.
TSL 3
New Member
Oct 10, 2018
4
0
Fullerton, CA
Any update on this issue with the rear speakers? I have this problem since I got the car 5 months ago. But doesn't look like a lose ground as that will make it intermittent all the time. Instead, this seems to be a software issue. If the rear speakers are on when you get in the car, they will stay on for the entire ride. If were off, they will stay off . All depends on the actual state when you get in the car first. Never happened to change during the driving or while the car was "on". Also couldn't find a way to turn them on when were off, even soft/hard reset not always solving the problem. Completely randomly... Anyone?! This is really frustrating... :( Thanks.
TSL 3
New Member
Oct 10, 2018
4
0
Fullerton, CA
This is probably obvious, but did you check the balance setting in the equalizer icon?
I'm going to go check my system right now...
Always checking that, just to "make sure" the rear is indeed not working. Since yesterday, 5 trips with the car, 2 times the rear speakers worked and 3 times didn't... :(
TSL 3
New Member
Oct 10, 2018
4
0
Fullerton, CA
That's a bummer- it's a lot harder to repair if it's not consistent.
Tell me about.... I went back to Tesla in Costa Mesa about a week after I got the car. When the guy checked it, of course, it worked just fine... He told me to do the reset thing and will take care of the problem. But it was not right, and since then, I was trying to figure out if there is anything possibly related to this, or causing this rather than going back to Tesla. Also I was hopping to see more people with this problem and eventually a solution here on the forum...
Feb 26, 2016
528
501
I had speaker problems with my 3 when I first got it. The rear speakers would cut out randomly and only return with a reboot of the center screen or if I got out and back in the car. They ended up finding a bad wiring harness in the headliner.
I was able to replicate it for the service center by striking the headliner where the hazard button is with my hand. I suggest you try this and see if it makes your speakers shut off.
Here is the part number they replaced...
ASY,HARN,HEADLINER,M3,PREM,NA,APA
C (1067970-00-E)
TSL 3
New Member
Oct 10, 2018
4
0
Fullerton, CA
C (1067970-00-E)
Thanks ! I tried but makes no difference. Again, to me seems more like software problem. Every time, but absolutely every time, the way it is when you get in the car will stay like that until you finished your trip. Never c hanged during the trip. So doesn't look like bad connection or lose ground or something like that. Even when doing a reset (hard or soft) sometimes fixes the problem sometimes doesn't. Just randomly works or not... :(
quigproquo
New Member
Oct 30, 2018
Kingston
Received my car on Saturday, October 27th, 2018 and by Tuesday, October 30th, 2018 I began experiencing speaker issues with my two rear speakers. It is essentially a tic toc sounds that persists through all audio playing. Just initiated contact with Tesla regarding a resolution. Will be sure to update forum as much as possible.
astrowunder
461
434
Wisconsin
I just spent 20 minutes in the back seat of my car listening to just the rear speakers with balance shifted fully to the rear. Everything sounds great, so it's not happening in every car anyway.
dabrew
5
4
King of Prussia, PA
i notice a huge difference between the front and rear speaker output. The front presentation is really great but the rears are very shallow. I have no reference point on another M3, but i don't think this is right. Anyone else experience this?
Reactions: IM_1406
IM_1406
36
30
Pennsylvania
Same ^...... :-( You are not alone.....
Dongshouyu
New Member
Jan 11, 2019
Philadelphia
I picked up my m3 2 weeks ago, yesterday my bass and rear speakers went out just like yours, I’m taking it into SC next week to have it checked out
Cbrigham
6
0
Victoria, BC
Did you ever figure this out? Just happened to mine yesterday. Sub is off entirely and rear speakers make a clicking sound. Front speakers work fine.
flashflooder
502
452
Charlotte, NC
The front woofers are 8”, while the rear are 4”. So there’s your answer.
