The screen is black when in reverse or when I choose "Camera" from the pop-up action bar. Model Y less than 2 weeks old. Is this a common thing that has an easy fix? I tried Powering off and back on. Lens looks fine.
Probable software issue. Have had it happen on both Teslas and software updates fixed. Still happens briefly sometimes when I transition from Netflix/YouTube to reverse gear.
Mine did this. Power off using the option on the screen, letting it sit for a few minutes without touching anything (including the door handle) solved it for me.
I had the same issue on my first day when I got it home. Scroll wheel reboot fixed the problem. Check your software version and make sure you are not on the showroom version. If you have gotten any updates since you got the car, that won't be an issue.
This happened to my MY as well today when I went to drive the car and it has not fixed itself after a soft reset. Version 2020.24.6.5 250a46d88d9c. I'm going to try turning off sentry mode and power off the car.
