  • The final cut of TMC Podcast #34 is available now with topics timestamped. We covered Tesla's rollercoaster prices, Toyota pushing junk science, Mike's new Model 3, Optimizing track mode for snow driving, FSD V11 apparently coming by the end of this week, and more. You can watch and check out the chat replay on YouTube.
Bad speed limit sign recognition
The speed limit sign recognition is not working at numerous locations on US Hwy 285 in Colorado (a major 2 lane highway). The signs are quite obvious and clear. It seems to be missing several 65 speed signs where internal navigation data with wrong speed limit data is overriding the clear signs. This is quite frustrating since it makes autopilot much less useful......
That isn't the real speed limit. It's more of a suggestion or warning. The true speed limit is always posted in white.
No bueno. While Virginia calls them “Advisory Speed” they clarify, “This sign indicates the maximum safe speed for a highway exit.” I anticipate Tesla will add them, flying into a sharp 35mph safe exit at 65 is scary.
T Chicago
New Member
3
3
Chicago
It seems that any white background sign with black digits is incorrectly recognized as a speed limit. In Chicago, there are signs for Route 50, white background and black letters and digits. My car always changes the recognized speed limit to 50, even though it’s a 30 MPH zone. This has happened for the nearly 2 years I’ve had the car. I don’t rely on my Tesla showing the correct speed limit. There are many speed limit signs that have different speeds for different vehicles and my car seems to always default to the slowest speed. I emailed Tesla to inform them of the issues, but I never heard back. It seems like this should be easy to fix, but maybe I’m wrong.
Note: This is NOT FSD beta... even with the Christmas update, this is STILL happening... for a couple years now.
Set AP to 65, and then I pass by one of these NOT speed limit signs... AP drops to a max of 47...
The rest of my daily trip, I have to switch to cruise.
I mean, they are close to the same thing... :confused:
We have speed limit for cars and trucks, side by side... you can watch the car bounce from one speed to the other for a few seconds before it decides on one.
Hello,
Has anyone found a way to get this if to Tesla? I travel to a town about 100 miles from me. There are two stretches of highway that the posted speed limit is 65 and my 22 m3 thinks it is only 45. This is for 20 and 25 mile stretches of highway at a time. The speed limit has been 65 for at least the last 5 years.
Hello,
Where is this? To determine the speed limit, Tesla uses a combination of a speed limit map dataset and the car's vision system which reads speed limit signs. When the two sources conflict, problems arise. Rumor has it that Tesla uses TomTom for its speed limit mapping dataset, so I can check the location for you. There's really not much you can do about it until Tesla issues another map update. Note: the map background used for navigation in the car's UI is Google Maps.
Update. With 2021.44.30.21 the car slows down to an appropriate speed at interstate exits where it used to fly into them at high speed. Much better. The display still doesn't show the exit speed limit, still shows 65 or 70 from the interstate, but it is dramatically improved.
Reactions: mangrove79
Can someone please educate me, on what takes precedence, a physical posted speed limit sign that the car should see and read, or what's hardcoded in the GPS Nav database? On long dives, my 2020 Y seems confused.
From what I've experienced it's what the car can see. I've had times where on the highway it's posted 70 for cars then 60 for trucks. If there's a truck in the right lane blocking the 60 sign the car won't change the speed limit to 60. If there is clear line of sight to the 60mph sign it drops my speed.
When my car sees a lower speed limit sign, the display updates with the new speed limit, but Auto Pilot never lowers the speed that I'm traveling at. I have to lower my speed manually with the scroll wheel, or by tapping on the speed limit sign shown on the display. Is there some setting that I haven't found yet to make AP automatically follow the posted speed limits?
Check here: Choose whether you want Traffic-Aware Cruise Control to engage at the detected speed limit, or your current driving speed. Touch Controls > Autopilot > Set Speed and choose either Speed Limit or Current Speed.
Also, my preferred method of adjusting my set speed to the current speed limit (and whatever offset you have) is to hold the right stalk down on first detent for 1".
Way more efficient than scroll wheel or tapping screen.
My "Set Speed" is set to "Speed Limit", but the car still never changes speed when the speed limit changes.
I didn't know about holding down the right stalk to adjust to the current speed, so thanks for that info.
My experience is that it will go with the last speed limit sign it has seen for around 5 miles, and then it defaults to what ever speed limit is coded into the Navigation database. For example, when leaving the town I live in I pass a 55 mph speed limit sign... 5 miles later (without passing any new sign) my "speed limit" drops to 25 mph... this is on a state highway, not some city street or gravel country road. I looked into the data on TomTom and it shows the entire road as 25 mph. So it looks like a physical sign takes precedence over the navigation data, but after around 5 miles it decides to default to the navigation system data. I just did a bunch of updates to TomTom for my local roads in hopes that it will eventually filter down to our cars. I suspect that crap loads of the data in TomTom is incorrect, but in the past nobody gave a crap because they didn't have a car that would limit their driving speed based on incorrect data.... we will be making corrections to this crap for years to come!
Keith
