The evtripper is awesome. It is exactly what I needed but did not have; i have it bookmarked on the Tesla now. My sincere appreciate and thanks to whomever wrote and provided that.
Actual numbers from my trip (including the slight detour for charging) [FOR CLARITY, by "actual" I mean "as predicted by evplanner based on my actual route, actual weather, actual load, 1x the speed limit, and my 21" tires; I did not collect enough log data to figure out my actual for comparison but it had to be pretty close to the predicted results]
Outside temp: 75 degrees
Headwind: 1 mile SSE (disregarded because the east vector of this would be minimal)
Load: 500 pounds (3 people, plus lots of equipment for kayaking and camping)
Speed multiplier 1x (I kept strictly to speed limit)
Car: P85S with 21" tires
Cabin Temp: 70
Actual Route Livonia, MI to Chicago, IL via Dowagiac, MI: 273.1
Results:
Energy: 95.6 Kwh
Avg Wh/mile: 350
Avg speed: 61
Up feet (elevation - hills): 6107 (!!! I NEVER noticed hills before driving this route in my Tesla!! Now I know to check this out; it is a huge factor I think)
Down feet: 5950
My "fill up" of 90 minutes with a 40A HPWC (single charger) added at most 15Kw (1.5 hours x 10Kw/hour max charge rate)... so in theory I had 100KwH and should have ended with 5KwH instead of zero.. but I suspect I did actually end up with something like 5KwH even though the speedo said zero .. because the car was still working, I did not get the "charge now" warning, and based on other posts it seems likely that there is close to a 5KwH buffer when the speedo says zero miles remaining. There are a couple of factors that introduce error that could account for some of the 5KwH difference too: (a) I had to charge at a public station and drove my car several miles in stop and go traffic to get back to my parent's house the night before, so I probably started with less than max charge (I wish I had looked that morning but I didn't); and (b) we made a 20 minute pit stop along the way to get coffee. I might have charged for slightly less than 90 minutes, and the HPWC probably put out slightly less than max of 10Kw (it read 28 miles per hour during the charge time whereas I think 31 is max). Thoughts?
The 350 is probably almost exactly what I experienced, though it is hard to calculate because I did not keep good logs. I know I was at at least 360-370 for the first half of the trip (arriving in Dowagiac, I was down to 70 rated miles whereas I thought I should have had 100+). I kept to rated pretty well after that, and got my consumption down to 215-250 Kwh/mile once I got into Chicago... but that probably didn't matter much because it was the last few miles.
Some interesting observations after running this simulation and trying some variations:
1) My "detour" through Dowagiac gave actually
saved me 3.2Kw even though it added 8 miles to my trip (as above post notes, running "straight through" Livonia to Chicago the evtripper calculates 99Kw expenditure or 372 Wh/mile! This is
exactly why I think it is critical to integrate the Energy App, something like the evtripper beta, and the Nav app... Had I followed the Nav app "planned" route, I would have been 3.2Kw shorter and probably would not have made it home even if I stopped to charge at a J1772 for several hours! Even without my "top off" in Dowagiac taking the county road detour save me 3.2Kw! But there is NO WAY in the UI of the car to determine a "best route" that will result in the least expenditure of Kw's (versus shortest route or so-called fastest route). If you look at the map, though, it really is not obvious that the detour saves any Kw's.
2) If you look at the segments along M14 (which runs through Ann Arbor and is especially hilly) my average Kwh/mile was predicted at 369 - 384 .. and the segment of I-94 up to the exit for Dowagiac average predicted Kwh/mile was 384. That accounts for the assymmetry that really concerned me (the fact that I was so short when I reached Dowagiac - almost all of my deficit versus the "rated" came from this part of the trip I think). I think that this "power suckage" was mostly caused by the hills - lots of up and down. It is an interesting failure of the nav app that elevations are not even displayed but they have such a big impact on Kw usage.
3) Slowing to 85% of the posted speed limits would have allowed to me make the entire trip without stopping in Dowagiac to top off. This would have increased the trip time from a little over 4 hours to 5.25 hours, but eliminating the charging stop would have given me back that time... though I would not have had the chance to meet S.C. and share a few cups of coffee at his place. All in all, I am glad I made that stop but it is interesting to note that such great savings can be had by slowing down. But back to my original point, which was that slowing down to 85% of the posted speed limit leaves you open to lots of road rage and I really think it is bad for Tesla's image to be consistently passed by Prius's. Most of us (I think) bought the Tesla at least in part because we don't want to have to drive slow and hypermile everywhere we go.
4) Changing to 19" tires would have given me an extra 5 Kwh (90 Kwh for the trip, avg Kwh/mile 331)!
5) Turning the AC to match outside temps (or presumably turning off Ac) would have given me back 1Kw.
6) Traveling on a non-obvious route (Livonia -> Romulous MI -> Cambridge MI -> Coldwater MI -> South Bend IN -> Chicago, IL would have allowed me to make the trip with a total expenditure of only 92.8 Kwh! but still achieve average speeds of 54 mph for a 284 mile distance driving posted speed limits all the way, and not changing any other factors (versus 273 miles at average speed of 61 and energy expended of 99Kwh for the straight through route recommended by the Tesla Nav app). By taking this slightly longer but not much slower alternate route, changing to 19" tires, and turning my AC to match outside temp of 75, I probably could have made the trip without stopping to charge (estimated 86.1 Kwh avg 303 Kwh/mile)... A very brief stop to charge at a public J1772 would have done the trick.
All of this reinforces my belief that the Nav/Energy apps need major upgrading to be more useful and not misleading. At the average expected expenditure for the hilly part of the trip of around 380 Kwh/mile, I would have had only 214 miles of range. But my "projected range" on the energy app never said so except when we were actually going uphill. Without my detour through Dowagiac, I would have only had 228 miles of range; and even with the detour I only had about 240 miles of range. That is still pretty darn good so don't take my criticism as a knock on the Tesla itself, just the UI.
Yes I am new to EVs but I really don't think the issue is my driving but rather lack of information (and now that I know, need for much more detailed planning). My point is, there is just no way for a human being to know the actual range to expect on an unfamiliar route, or the shortest energy path between two points on that route, without running a tool like evtripper. It might be obvious to a hypermiler that it is better to go around a mountain at a cost of adding extra miles, versus the shortest mile path which might be over the mountain .. but when you are traveling over hills that you barely notice when driving, a computer is needed. Same for alternate routes that add miles but at lower speeds. Or travelling in the morning or late night when the weather is cooler versus mid-day. Or turning off your AC entirely and opening the windows. It is easy to know that all these things affect range, but by how much? I like to know exactly how many miles I have left. Rules of thumb and even intuition from experienced EV drivers won't provide that level of info if the route isn't familiar.
From now on, I will use evtripper every time I road trip. But what if I hit construction? Or decide to take a detour to sightsee? Etc. The nav system in our 100K car should be able to handle the task.
Personally, if Tesla would provide the APIs and the ability to load my app on the car, I would be happy to rewrite the code and donate it to the community. Rewriting the navigation app to calculate the least energy expenditure route would NOT be difficult. I was a programmer in a former life, and when writing navigation applications you break the geography into segments .. assigning "weights" to each segment based on miles divided by traffic speed (actual or posted depending on available data) and then do a search using one of many well known algorithms to determine shortest path based on the weights. "Fixing" the nav app would simply involve changing the assigned weights on each segment. Rather than using traffic speed, you would use Kilowatts for each segment (which would be determined by traffic speed, temp, elevation up/down, load, wind, etc.). Once the weights are calculated for the area, the shortest path algorithm would not need to be modified at all - its determination of shortest path would be the least Kw usage based on the calculated segment weights. This would take a programmer knowledgeable with the Nav and Energy apps source code a couple of days, max. It would really be great if Tesla opened up the source code for the Nav and Energy up so we could play with it if they don't have the resources to do it.
It is hard to see because i had to shrink the image to get a good screen shot, but I have attached the route planner detail...you will definitely need to zoom in to see numbers though
