Carolina vs Texas BBQ?
I think it's a Bama (Alabama) thing, but I don't object to using mayo on the grill. The tartness cooks off and prevents sticking and burning which is great for fish and elote. As for me, I'm use lump charcoal and a chunk of wood for smoking in my kamado grill. I recently learned to not soak the wood beforehand and to let the initial smoke clear before smoking the food...it's less acrid and bitter. Also, can't go wrong with Korean BBQ, but sending my Tesla to Korea of battery service is completely out of the question.Amazing. lol.
As is the case with this analogy, I think pretty much all BBQ is great. Unless of course you put mayo on BBQ. Then you should be arrested. Do not pass go. Do not collect $200. Straight to jail. Unfortunately there's some shops out there putting mayo on BBQ. Should probably avoid those and stick with Texas and Carolina.
Reliability history on 2015 and newer Model S HV batteries is currently masked by still being under warranty. Therefore, any issues are being covered under warranty without any owner cost.Thanks @Recell for the reply. That brings some good light, especially the software better detection algorithm.
Reading through this forum I had the impression that battery packs (90KWh maybe?) up to and including 2015 builds are prone to the "8 years and 3 months" failure. Overall earlier batteries seem to be more error-prone, is it? From your experience, do you see some better reliability of packs post some build date/time? Thanks again
What's the point of posting ur restricted links here??Problem is fully reverse engineered and debunked. It is safety mechanism because battery is in defect. Repair the battery and then reset BMS.
Full procedure here.
BMS reset algo here.S X Battery Master training operation manual #2023612001
Parasitic cell damage. Water ingress . Wiring. Crash incident / mechanical damage. Normal tear&wear BMS_f107, BMS_u025, BMS_u029, BMS_f123, BMS_f098, BMS_f097, BMS_u018 -XX Copyright Copyright Copyright Copyright Copyright Copyright Copyright Cevclinic.eu
Model S and X BMS File Reset u029 u025 f107 f123
Model S and X BMS File Reset u029 u025 f107 f123evclinic.eu
Hi, where can i buy this device which erases the u029 error ? Is this performed via the diagnostic port or is needed fizical access to the bms board?A very interesting point is Tesla has it coded in their software to ignore u029 if they want by setting a flag on the MCU. See image. Read what you want from that.
We have studied the u029 error a lot. It seems on older cars there are many false positives out there due to imbalanced CAC on aging packs. We try to ask everyone for individual cell voltages prior to selling them a device. But otherwise the device pairs with the car and records pack condition. Only if the pack seems healthy do we send the command to turn off the error. And with the device paired to a car you won't get someone who buys one to clear a fleet of cars. We may unpair/reset a device for a fee but that hasn't been decided yet and will likely be on a case-by-case basis.
As for open-source. I am willing to talk about some of what we do to qualify the pack, but will not open source it outright nor disclose exactly how we turn off the error. I've got nearly a year in on this and need to be paid for my time.
Don't do it. You don't want to create a fire bomb.Hi, where can i buy this device which erases the u029 error ? Is this performed via the diagnostic port or is needed fizical access to the bms board?
Don't do it.Hi, where can i buy this device which erases the u029 error ? Is this performed via the diagnostic port or is needed fizical access to the bms board?
I agree with you that resetting the U029 error without inspecting and fixing what caused it is dangerous. But after a battery repair is a must and Tesla toolbox doesn`t clear this error .Don't do it. You don't want to create a fire bomb.
Toolbox does provide a reset, but given the potential for abuse it remains undocumented.
