119 estimated miles while having driven an actual 94.5 miles
106 est miles decrease for 93 miles driven
254 mi on the battery (set at 80%), I traveled 99 mi (based on the odometer reading) yet the battery gauge is at 69 mi when I should have about 155 mi left.
When you say estimated miles do you mean Rated Range change? Since RR is under standard conditions and your driving was not these numbers actually seem pretty good. If you use the nav and watch the energy graph you can see how well the actual drive matches up with the predicted consumption which is an actual estimate of the trip and not an estimate of battery capacity under standard conditions.
That does seem extreme. Short trips each starting with high Wh/mi contribute. Car not sleeping between trips steals efficiency (third party app keeping it awake?). Recommend monitoring the consumption, it is on the trip card lower left part of the screen.
My driving is mostly on residential/side roads w/ 25-45 mph speed limits and I usually keep to the speed limit. My trips are under 20 mi round trip, no long trips, just shuttling back and forth from school (7 mi round trip) and errands. There are times I'm on a highway doing 60-65, but it's for only a few miles, at most. Loss of range is worse the more I'm on the highway. Just drove 3mi on the highway at 60 mph, but used 8mi of battery range.
Cabin overheat is turned off. Garage parked every night and only charge when I'm at around 50-70mi left on the battery gauge.
Thanks,
MJK8
Multiple short trips use LOTS of energy, so that’s why I asked the question.
Tesla recommends that you keep the car plugged in every day - why aren’t you doing that?
What is your wh/mile consumption? Swipe right from the lower left corner of the touch screen to display this.
While many short trips may consume lots of energy, I still feel my range is well below where it should be. I'm only getting 130 -135 miles on a full charge. Several short trips should not consume ~50% of the battery's energy/range.
I never knew Tesla recommended charging every day and feel it should not be necessary to charge my vehicle every day, especially when I still have 200 miles of range on the battery. Why should I plug it in? After all, you don't go to a gas station after traveling 50 miles in an ICE vehicle to get the best gas mileage, nor do I plug in my cellphone when I'm 80% battery capacity to keep my phone working properly.
I will check my Wh/mi consumption the next time I get in to use the vehicle.
Thanks for the input,
--MJK8
So, you're asking why you should follow Tesla's recommendations regarding charging your $50K+ vehicle?!? Really??
With no disrespect intended, at this point commenting on your situation any further is pointless until you provide photographic evidence of your range claim so that we can begin to ascertain the truth/causes.
I will try to get some physical evidence posted to help determine my issue.
As i mentioned in my reply, I was not aware that Tesla recommended charging every day/night. Even doing so would not change the poor range I'm getting. Traveling 10 miles and losing ~19 miles on the battery, then charging to full does not solve my issue of getting only ~52% of the battery's capacity/range. If anything, IMO it conceals the issue.
Are you /Tesla saying charging every day may solve my problem? Will my battery become more efficient the more often I charge it? If so, I will start to charge it every day.
It maybe my fault for not knowing Tesla's suggestion of charging every day, but I feel that a +$50k vehicle should not need to be charged every day to get the full use of the battery/range, especially when you still have 80% of range left on the battery.
Getting 130-135 miles on a full charge when you're supposed to get ~250 miles is an excessive short fall even if you're charging once a week.
Had I known that I would be getting 52% of the battery's range for charging only once I fall below 100 miles of battery range (which it what I've been doing), I probably wouldn't have bought the vehicle. Throughout my research on Tesla (all models) and other EVs, no where was it ever mentioned that you would lose 48% of your range if you don't charge every day.
I don't mean to come across as argumentative as your input and knowledge is greatly appreciated. I'm just extremely frustrated with my situation and at this point, very disappointed with my Y.
--MJK8
--MJK8
Where did this situation land? I am experiencing the exact same thing. I'm getting just over 50% of the range I'm supposed to get and I believe it's because of multiple short trips. And unfortunately, the wh/m won't tell you anything. My rated range is based off 225 wh/m and I am often getting around 250 or 240 based off the car's trip computer. This would suggest I should get very close to the cars rated range. Yet, I loose tons of kilowatts when the car is simply parked. I hear the fans running for up to an hour even after a short 5 or 10 minute trip. No sentry mode, no app usage, no summon stand-by, no nothing. I believe its all coming from the battery conditioning, but its seems excessive and I can't get a straight answer from anyone. Happy to see I'm not the only one, but I still want to get to the bottom of this problem. Lastly, have you taken a long trip yet. And if so, did you get anything close to your rated range on it?
As well as that underutilized resource called the Owners Manual...SuaveWash: Welcome to the TMC forum! This is a great site to learn how to understand how your car functions.
Spending some time reading on this site will clarify many of your questions. You will need to do some reading to gain a deeper understanding of how your car functions.
I got my first Tesla a couple of months ago, and found an important tip to remove most of range and battery-degredation anxiety... set your display to show percent instead of miles. That one little thing made me enjoy my MY so much more.
That does bother a lot of people, but I try to remind people that the number on the display is not "miles". It is "rated miles". That is an amount of energy scaled by an efficiency constant from the EPA ratings testing. And as we should all be familiar with, the EPA testing methods are kind of like your nearsighted granny drives. That's always going to be pretty optimistic versus most people's usual driving.This is probably to the way to go. I am stuck on "why does 17 miles take 20+ miles of range?"
