dhrivnak
About a mile a day is par for the RoadsterI am losing 1-2 miles of range in the Model3 over 24 hours... you really need to take that car in to service center and have it interrogated.
I think what happens is when the car discharges enough to get near the bottom buffer everything shuts down and there is no more vampire drain. You then need Tesla to "wake the car" back up. With no drain the cells should not discharge any further on their own. I have bare 18650 llithium cells that have been sitting for years and still show a charge.I don't know whether that is actually the case or not, but my guess would be that is only when the car is put into a deep sleep/low-power mode... just parking and walking away for a year (even on a mostly full charge) has too much vampire drain for that to be ok.
It is extremely likely that the balancing circuit is always connected to the cells thus this is not equivalent to an isolated cell.I think what happens is when the car discharges enough to get near the bottom buffer everything shuts down and there is no more vampire drain. You then need Tesla to "wake the car" back up. With no drain the cells should not discharge any further on their own. I have bare 18650 llithium cells that have been sitting for years and still show a charge.
I seem to remember Tesla saying a Model S can sit for a year or so without damage.
Model S batteries also have the ability to protect themselves as they approach very low charge levels by going into a “deep sleep” mode that lowers the loss even further. A Model S will not allow its battery to fall below about 5 percent charge. At that point the car can still sit for many months. Of course you can drive a Model S to 0 percent charge, but even in that circumstance, if you plug it in within 30 days, the battery will recover normally.
Actually it (inductance) is a big advantage. It allows pulse width modulation of the heating with a near DC current from the battery (which the inverter naturally does). This means that the model 3 battery heater is more versatile than that found in the S or X.
I'm having my doubts about OP's story. Something doesn't pass the smell test.
And yeah, why would the cabin temperature be 40 degrees higher than ambient unless the owner told the car to stay heated (camper mode, using some 3P computer software that connects to the car, etc.)?
I expect SFInvestor21 is running off canned FUD talking points.
Bitcoin minerI'm having my doubts about OP's story. Something doesn't pass the smell test.
Possibilities: The car wasn't turned off. Or the cat was out driving it overnight. I would check the odometer.Question is why would the car maintain cabin temperature if it was off and not something that was selected or requested?
Did your cells that sat for years start with a 3% charge? Just because they retain some charge doesn't mean they have anything like their original capacity
Hey @jomo25, here you go.
Quick update! So I did end up leaving my car out last night, temperatures dropped as low as 28 degrees F. Car dropped from 132 to 117 Miles. Much better than 100 drop. Before I went to bed I did notice that my interior temperature was holding a solid 65-70 degrees as i monitored it for an hour (even though outside temp was 33). Before going to sleep I decided to switch off my Bluetooth maybe thinking proximity had anything to do with maintaining temperature or what others have said maybe my car is turning on and off. Anyways, happy it didn’t happen again for now.
