That's a pretty typical brood nest frame. White-capped cells on the outside are honey, dark-colored cells to the inside of those are filled with pollen, and the yellowish-capped cells in the very inside are brood (along with larvae). I see plenty of larvae in the cells there in your picture, just geting ready to be capped. Look for the little white worms in the cells.
That is *beautiful* wax, by the way - gorgeous white cappings!
I've highlighted some in your picture where the larvae are very visible - most of those cells in the center have larvae in them at various ages (and will be capped within a day or two):
Your brood frames will get darker with time as the comb turns dark, then it's very, very easy to see larvae and eggs.
As for finding your queen, don't despair -- it takes a while to get the hang of it. The queen typically likes to seek the darker side of the frame. When I pull a frame out and tilt it up toward the light, I always look toward the edges of the frame because chances are that she'll be running that direction. This morning I checked on my first swarm installation, and found her right away. She kept running around the bottom of the frame as I flipped it back and forth.
