anyone know a a dash cam that I can install that I can view on the internet/app when I am out of state. I want to be able to view the camera feed live if possible. Any thoughts??
I got the Garmin cam installed
I had one of these from Taobao, they are so bad that I kept them in the box, never bothered to put it on the car... I just threw it away last week when I was moving...
I now use a Mio MiVue 568, much better video quality both day and night... got it for 1550 HKD without SD card.
I have to use an extension cord when I connected to the cig port... The factory one isnt long enough.
Installed the Blackvue 650 (front and rear cam, connected to the 12V power outlet) for about a week. The cables fit well in model s in terms of length and "hiding". I had concerns on the cable conneting to the rear carmer but it turned on it was long enough and well hidden. Like the wi-fi function which allows me to extract the video into my phone and I can view it on spot. Image is acceptable to me.
The negative is mainly the front cam's visual angle which I think is narrower than Blackvue 550. Also, there may be some echo in the playback if you turn on the mic for audio recording.
My friend help me installed the cam. You can get ignition power from the fuse box using or get the constant power from the 12v battery located behind the nose cone.
The wire then run through the driver side fender and get into the cabin from the gap of the driver side door, and got its way to the mirror from the A pillar (he did pop off the cover)
Hi jkhfung,
I installed it myself and the works were indeed not as hard. Because MS is large, it has plenty of room for you to hide the wire. The blackvue 650 includes two cams (front and rear). To put the system in place, I connected:
1. the power source from the 12V plug to the front cam (via the glove box) on the left side of the car
2. the cable cord connecting the front cam and the rear cam hidden via the edge and inside the rubber in contact with the doors on the right side of the car.
I am happy with the installation results. The two cables mentioned above are long enough and make thing easier. Also, not that many tape or sticky mounts are required as the cables fit in well in the gap between the rear mirror and the ceiling as well as inside the rubber. Regarding my own case, I installed the part (1) in above first and it took me about 20 mins. I did the second part few days later and it took me about 45 mins (longer time mainly because I tried different "routes" and checked for the outcomes). One thing I need to draw your attention - if you opt to outsource, don't let the guy connect it directly via the fuse box because it might void your car's warranty.
I am by no mean a handy man but the installation is really not that difficult and I would recommend DIY.
Let me know if you need anything further.
