Hi jkhfung,
I installed it myself and the works were indeed not as hard. Because MS is large, it has plenty of room for you to hide the wire. The blackvue 650 includes two cams (front and rear). To put the system in place, I connected:
1. the power source from the 12V plug to the front cam (via the glove box) on the left side of the car
2. the cable cord connecting the front cam and the rear cam hidden via the edge and inside the rubber in contact with the doors on the right side of the car.
I am happy with the installation results. The two cables mentioned above are long enough and make thing easier. Also, not that many tape or sticky mounts are required as the cables fit in well in the gap between the rear mirror and the ceiling as well as inside the rubber. Regarding my own case, I installed the part (1) in above first and it took me about 20 mins. I did the second part few days later and it took me about 45 mins (longer time mainly because I tried different "routes" and checked for the outcomes). One thing I need to draw your attention - if you opt to outsource, don't let the guy connect it directly via the fuse box because it might void your car's warranty.
I am by no mean a handy man but the installation is really not that difficult and I would recommend DIY.
Let me know if you need anything further.
Hi Luckylao, thanks for the encouragement and I think I will give it a try. You mentioned the connection should not be routed through the fuse box, so direct connection to the battery terminals would be your recommendation ? thanks for the guidance.
