Except for the risk of fire, the severity is less with low SOC.Once a battery fire starts, does it really matter?
How do you all feel bout using RecurrentAuto for your battery data? I'm having mixed feelingsMy only complaint about Recurrent is it keeps waking up the car several times a day. If I’m not using it I prefer the car to sleep.
Personally I keep my battery at 80%, and my commute is 39 miles a day on average.
I use both teslafi & recurrentHow do you all feel bout using RecurrentAuto for your battery data? I'm having mixed feelings
So if you have 100% charged battery and you use all of it, you should charge it to 100% and its best practise? I don’t believe that.As I recall, Elon once said the lowest battery degradation may be obtained by only adding enough charge to replace what was consumed. I paraphrased that because it has been a while and I don't have 100% recollection.
We have charged my wife's 2018 Model 3 LR at 80% for daily use and have had minimal battery loss.So if you have 100% charged battery and you use all of it, you should charge it to 100% and its best practise? I don’t believe that.
I would guess 12% or slightly more, reading San Diego as the home base and 80% counting from the full pack when new. That’ll be about 10% range loss.We have charged my wife's 2018 Model 3 LR at 80% for daily use and have had minimal battery loss.
Yup!Battery degradation is mostly due to high(er) pack temperature and high(er) SoC, with the combination of both at the same time being a fair bit worse.
where do you see a teslafi degradation? The battery report I see only seems to compare EPA numbers with current range. It is also using a number that wasn't even the EPA rating when I bought the car but for some reason I don't remember Telsa bumped it up by about 5% after some update.I have 66000km on my MY now. I charge to 100% every Sunday and make the same 400-ish km round trip. During the summer months, I get back with 5-20% charge, but during colder months, I need to SC, sometimes up to 25% or so. I do time my charging so that I stay at 100% for no longer than 30mins before departure.
We also do about 4 long road trips per year, each lasting perhaps around 3000km. Obviously, all of these are SCed. We sleep at camp sites, so we are back to 75% charging unless we see long journey ahead. I never exceed 75% at SC due to charging speed and my (frequent) washroom break need.
I'm still on the original tire at the moment as during the winter I used another set. I initially set daily top-up to 80%, but about 6 months ago, I lowered to 75% as I don't seem to need 80% at all except for the weekend trips.
Based on TeslaFi's estimates, I lost 4.9%.
I don't worry about battery degradation at all, and we plan to keep this car until we go past 200,000 miles.
Teslafi compares to the initial range and also the highest and current range for a specific (your car).where do you see a teslafi degradation? The battery report I see only seems to compare EPA numbers with current range. It is also using a number that wasn't even the EPA rating when I bought the car but for some reason I don't remember Telsa bumped it up by about 5% after some update.
So the day I drove mine home I already had about 9.5% 'degradation'. I do readily admit I'm not sure how to read that battery report nor have a clue as to the parameters you can adjust.
What car and year do you have?maybe it's different here in the states. Below is mine. That 323 is the EPA that is higher than the EPA when I got the car (see above EPA increase after update).
This is with setting no dates so presumably from I joined teslafi which would be a couple weeks after delivery.
Also interesting is if I go with the last 12 months, I have a percent gain. From a seasonal, driving habits, etc range gain is certainly possible. But it can't be a negative battery degradation.
Bottom line; I don't see how one can get battery degradation from this report.
2020 MYLR induction wheelsWhat car and year do you have?
In general, the real EPA range is not changed during a cars life.
There van be updates to the displayed range, often quite early in the cars life like mine M3P ’21 which showed 499km(310mi) for the first month, until the car was updated to the specified EPA range (507km/ 315mi).
I do not see the ”fixed” certfied EPA range in your graph as a comparison but I see the range that teslafi calculated, which might match EPA.
My car did show full range (315 mi or 507 km or sometimes 508km for quite some time on full charges and also in scan my tesla (BMS Actal values), but Teslafi jumped up and down during this time due to the rounded SOC which causes a rounded max range calc. During this time the scan my tesla/teslalogger data showed a much more consistent range and battery capacity.
I tried going through the help section but couldn't find any explanation on rated miles.
The original EPA was 316 (just double check the window sticker) but after an update changed to 323. Looks like , according to NotATeslaApp, that that was 2020.40.7 / 2020-10-16. The notes don't indicate what the number was but my memory is 323. That's why I figured that rated 323 was EPA.
