Thank you, I skimmed through some of that rather long thread and found a bunch of conflicting info.
Some say go 275, others say that 255 is the max that fits in the front. There was one post about offsets that implied that the factory setup has zero scrub radius, which, from the little that I’ve read on the subject, is not typically done or desirable.
Has there been any consensus on what is the max front tire width that would not rub?
Also, when going wider, should one ideally stick with 40 mm offset to preserve the original scrub radius or is some other radius desirable? I’ve seen that the poll skews toward a lower offset, which would increase the scrub radius, likely making it positive. From what I’ve read, a positive scrub radius is generally not desirable in road cars. Why are they skewing lower then?
I feel I’ve read enough on the subject to know that I know nothing and, in the absence of expert guidance, I feel I should probably stick with the defaults (40 offset in this case). Those forged wheels in the poll, assuming good mfg quality, surely look compelling price-wise; I just can’t make an educated choice on size and offset.
I was originally going to get some bigger BBS wheels with the default offset, from the tire rack. They’re quite a bit more expensive, also heavier and just flow-formed vs forged. Surely they’re too much money for what they are (brand premium perhaps). How soon is the first batch of Titan 7 expected? Perhaps I should wait to hear some user feedback before buying any. Are MPP going to trial them?
