Tesla only charges about $50 to do the replacement.
Mobile service is on the way to my house and should have my Model 3 and Model Y completed shortly.
The Tesla DIY video shows how. It is a T-20 for the screw. A small wrench helpshey folks, I have a late 2018 Model 3, changed my cabin air filter two years ago and recall it wasn't easy but didn't take long. I'm replacing again, and now when I look at the self service Tesla video that HVAC cover on the side looks totally different in the video. Okay, I read here they changed it....good move. But, it doesn't help me. I can't recall how I did it before, just that the screw was a bitch. Does anyone have a picture or clip or anything, to help me find the right screw to undo, in order to pull the cover on the older models?
The only change for the model 3 is the screw is on the bottom of the cover rather than the top. Same cover just reversed.the video used to show directions for my early year model, now it shows for later models....it's changed.![]()
Yeah, I will have to call BS on that claim.They changed the filter cover screw location in the 2021+ cars and it's pretty easy to change filters in the newer cars. I've done it a few times now, could probably do it in about 5 minutes.
For me, Step 3 is to remove the thumb screw that I replaced the T20 Torx screw with. No need to use tools, I just reach in there and twist it off with my fingers.Yeah, I will have to call BS on that claim.
Step 1: unfasten clips and remove lower glove compartment cover, detach the light and speaker wires.
Step 2: unclip ~dozen fasteners to remove center console carpet panel. Now collect and re-install the white paper clips back onto the panel so that you can reinstall it later. Fish them out from inside the center console if any fell it (else they will rattle later).
Step 3: remove stupidly placed T20 Torx screw and remove plastic cover panel
Step 4: move seat as far back as possible, slide you upper body into foot well and legs up over the back of the seat. Now you have reach and leverage to remove the 2 old filters from the airbox, and finagle 2 news ones back into it.
Step 5: repeat steps 3-1 in reverse order. Search YouTube if you need visual aids.
Step 6: have a beer.
This may take you 10 minutes if you have Cirque Du Soleil on your resume.
Otherwise, figure at least 30-45 mins, assuming you are limber enough to execute #4, and have all tools, supplies, and beer on hand.
MY21+ cars make step 3 a bit easier, but that's about the only difference.
HTH,
a
P.S.: I did HVAC filter replacements on all my cars in March. Tesla Model 3 had the WORST in terms of being engineered-for-service. By far.
P.P.S.: BMW was mid-point. Honda was the best, be far: open the glove box, unclip two push buttons to let it drop lower, unclasp the air filter cover knob, open/replace, done. Zero tools required, truly a 5 minute job the first time around (more like 2 mins the second time around). That's what a well though-through and well engineered solution should look like! Bravo Honda!
P.P.P.S.: Tesla HVAC Team - massive fail!
I went with this option last time and it eliminates having to deal with the screw holding the cover on, which in my opinion is the worst part of doing the filter change. The magnet seemed strong enough to hold the cover in place just fine.You can also try one of these for easier access.
Air Filter Magnetic Cover
The Air Mag Cover is a USA-designed Cabin Air Filter Magnetic Cover for the Tesla Model 3.abstractocean.com
hey thanks, that's the ticket....got it done in like 15min once I found the correct screw and cover.The only change for the model 3 is the screw is on the bottom of the cover rather than the top. Same cover just reversed.
YouTube has many videos. This one is an earlier Model 3:
correct, I do it the same way, kneel outside the car and bend up, can't imagine doing it on my back.Also for me, Step 4 is to kneel on the ground right outside the door and bend over into the passenger footwell so I can do the replacement. I find this easy to do and don't know how people can do what you describe.
My Tesla buddy is a 2018 guy and said he’d walk me through the change. He arrived with a little screw gun, two universals, and two extensions. He was happy to discover my screw on the bottom. I bought two of the knurled screws, and he is happily looking forward to a more simple process on his car.hey folks, I have a late 2018 Model 3, changed my cabin air filter two years ago and recall it wasn't easy but didn't take long. I'm replacing again, and now when I look at the self service Tesla video that HVAC cover on the side looks totally different in the video. Okay, I read here they changed it....good move. But, it doesn't help me. I can't recall how I did it before, just that the screw was a bitch. Does anyone have a picture or clip or anything, to help me find the right screw to undo, in order to pull the cover on the older models?
Considering the filters themselves are $34, so only $31 extra for mobile service seems like a no-brainer, knee/back saver for me. But I shouldn't need the service for a while with just over 3K on the odo.Not having any yoga-like flexibility nor any urges to disassemble any part of anything, I’ve had Tesla replace my cabin air filters on my 2018 M3LR biannually and I’m due next month. It has always been done in my driveway by a mobile ranger for about $65, includes two new Tesla filters, and about 12 minutes. In my case, that’s money well spent. I do not experience the nasty HVAC odor some people do. For those folks, Tesla will also clean and spray the affected areas with the filters out to remediate the problem but that ups the costs to about $175, again a mobile service.
