Does anyone know if there is a way to disable the auto lights function when starting the car?
I have my car in the garage, and every time I start it by stepping on the brake pedal, lights go automatically on because the light inside is dimmer, even if the garage door is open. I then drive 50 cm forward and the sensor detects the full daylight outside, and turn lights off.
To do so over time, again and again, reduces the lifespan of the headlights (when HID lights startup, the ballasts run 23kV across the bulbs, to heat up the gas in the capsule to the right state. After a minute or so, it reduces the voltage, because the bulbs are hot enough that it only has to maintain the temperature. The more you switch them on and discharge those 23kV, the more you reduce lifespan).
Does anyone know a way to disable the auto lights upon starting (i.e. stepping on the brake pedal)? If you manually select lights off, it enables auto as soon as you step on the brake pedal...
