Wishful thinking I guess. V7.1(2.9.172)Just got my second update to 7.1 well get back about firmware version bit hoping there is summon :love:
Glad I'm not the only canuck still waiting for 7.1.No update. Still on 7.0.
same here, had been waiting impatiently with 7.0 until I checked the car about half an hour ago and finally noticed an update waiting. VIN115xxx.Just got mine this morning, still trickling out as part of the phased deployment mechanism.
That's not new, mine does that on 7.0Found that 7.1 now gives Android notices while Supercharging. One was "nearly finished charging" and the "charging complete".
Thanks Chris.I looked into this while I lived in a condo. My building (like most condos) used a different technology than home garage doors. I don't recall the specifics (frequency or encoding or something) but it meant homelink would not work. It also meant the generic, replacement or auto-learning remotes from your local auto centre won't work either.
Ok... I'm in Burlington right now... Driving on hwy 89 I had a timed nag at exactly 3 minutes... A couple times in a row. The nag was the same whether it was just enabled or I removed the nag by moving the steering wheel. I was driving 55mphHaven't really had the chance to test it until this morning. From what I can tell, I did not get a timed nag at the 1min or 3min mark. My route did not allow for more testing. I'm driving to Burlington next weekend, I'll have a definitive answer... I'll also be able to check if the behavior of the car changes when I get in the USA
Is it possible you're dealing with a system that uses a rolling code? If so, you'll need to find the magic button the door lift itself... as explained here: Homelink Garage Door Opener ProgrammingI looked into this while I lived in a condo. My building (like most condos) used a different technology than home garage doors. I don't recall the specifics (frequency or encoding or something) but it meant homelink would not work. It also meant the generic, replacement or auto-learning remotes from your local auto centre won't work either.
Driving on 401 to Windsor and I75 to Dayton yesterday, nag at every 3 minutes. I really don't object.
