@Hitman007, I didn't see the "
always open fully" button on my screen. Mind you, I didn't open the trunk/fwd completely, just more than the initial opening. Regardless, holding down the trunk button until it beeps is *supposed* to save that setting at that GPS location, which it is not.
The manually actually says, "
1.
Open the liftgate, then manually lower it to the desired opening height. 2.
Press and hold the button on the underside of the liftgate for two seconds until you hear a con rmation chime."
Maybe it currently only saves position when it's lowered (not raised). I will try this experiment again by raising it past my desired location, then lowering it before trying to save it (can I outsmart a Tesla?).
