It does. I'm using it with mine.Did anyone tested the Alcatel USB LTE Modem with the latest release to see if it works?
Which model that you get, if you don’t mind me askingIt does. I'm using it with mine.
I have the same Alcatel USB LTE Modem and am also on T-Mobile. Mine has no problem connecting. I think the author suggested to someone facing similar issues to make sure the power supply is providing enough power to the pi. Aside from that, not sure.So just finish installing 44.2 and still the Alcatel USB LTE Modem does not connect the cellular network. Keep having the blue flashing light which means - found LTE network and trying to connect. If all works the light turns solid blue (means it connected) - which I get when I connect the Alcatel USB LTE Modem through my micro router (so both the modem and my cellular plan is working when connected to another computer). I think the problem could be with the string Tesla Android is using to enable the cellular network which works with some but not other cellular networks. I am using T-Mobile.
What cellular network are you using?
Doesn’t work. I reported issue on GitHub & will supply Michael with some debugging info he requested. I’ll do this in a few hours during my afternoon mandated 15 minute breakDid anyone tested the Alcatel USB LTE Modem with the latest release to see if it works?
Interesting pattern. My provider is tello too which uses t-mobile network & my Alcatel is not working on tesla android but works on windows. Michael asked me for some debugging info which I’ll get to him today.Thank you. Will check. Although I am using the T-Mobile network, my provider is actually Tello. No other computer sees the difference between T-Mobile and Tello and actually all are set to use T-Mobile and it works. So, if it is not the power supply it could be some nuance with Tello and Android Project???
My modem, from the eBay order is an "Alcatel LinkKey - IK41UC | LTE AT&T / T-MOBILE UNLOCKED USB Internet Dongle". Works fine for me, my carrier is AT&T.
Yeah, highly doubt it's power related. I put an inline USB tester on my setup a while back and it draws very little in practice. I may have posted a pic a few pages back.
Cool. What tester do you have?Yes, agree. I have a similar tester with a load adapter and that is what I used to check the power supply capacity for 3 amps and it passed.
I can’t get internet via Bluetooth hotspot anymore
