Wrong. The requirements are that every NEVI stall can deliver 150kW
at the same time. (Regardless of if that demand ever happens.) All V2 sites and 4 stall V3 sites are non-starters. (A 4 stall V3 Supercharger can only deliver ~90kW to all 4 stalls at the same time, while a V2 site can deliver a maximum of 144kW to a single stall.) No software reconfiguration can change that. At an 8 stall V3 they could potentially handle it via software, by crippling the other stalls when the NEVI stalls have demand,
assuming the transformer is big enough, not every V3 site can even deliver the ~90kW per stall. (I think I saw where one 8 stall V3 site only has a 500kW electrical feed, so it would max out at ~125kW per NEVI stall, i.e. would not qualify.)
And while currently 4 simultaneous cars pulling 150kW is currently unlikely, it will be more likely in the future as more cars are capable of that. Some examples of vehicles currently on the market:
- The e-tron can pull 150kW up to 73%
- The Taycan can pull 150kW up to 72%
- The Ionic 5 can pull 150kW up to 69%
- The EV6 can pull 150kW up to 67%
- The EQS can pull 150kW up to 56%
- The EQE can pull 150kW up to 53%
- The iX50 can pull 150kW up to 50%
Note: all of those are based on starting higher than 150kW, so if they are only charging at 150kW from the start they might be able to take it even longer.
Can you imagine the outrage if there was an e-tron, Ionic 5, EV6, and EQS charging at an 8 stall V3 site along with one Model 3, and then another Tesla owner pulls up and suddenly the two Teslas can only get ~60kW each. Then a third Tesla plugs in and all the Teslas drop to 40kW. All while the non-Teslas are all still getting 150kW. And there is still one more stall available. Another Tesla plugs in and the Teslas can now only get 30kW each. Yes, it might be rare right now, but as EV adoption increases it will get much more likely to happen. I would be
very surprised if Tesla did this.
At sites with 12, or more, stalls, and ample power available, it would be more workable. (But really I think the most they would do is dedicate one NEVI stall per V3 cabinet, so it would have to be a 16 stall, or larger, V3 site, again with ample power available from the utility.)
