OOSM got 216kW on their Model S Plaid at a EA station that was just updated to their new gen chargers:Best I have managed was 197kW
And they started at 23% and didn't precondition...
You could be right. So maybe something on the adapter pin is indeed a better idea. I haven't yet had a chance to look into it.There is a possibility that it might interfere with the sensor that detects a charge port door push.
It should fit since it fit the Korean Tesla CCS adapter which is exactly the same as the Tesla one (I have both). but that case you linked to us out of stock, you can probably do a custom order from Harumio for one but it is $60 instead of $45.Has anyone tried the official shipped from Tesla North America CCS adapter in the case from Harum (this one: Tesla Model 3/Y SEXY BAG CCS Combo 1 Adapter Case I’m sure it’s a perfect fit but would like some confirmation from someone who’s actually tried before I order.
Well on the weekend I did a road trip and ended up using the adapter twice. Both time is would not lock to the handle.How about those small felt bumpers you can get to prevent cabinet and drawers from slamming. The ones I have are about 1/4” Od round by 1/8” thick. Sticky backed. Maybe something like that would work.
I will have to check my adapter to see if the pin is fully depressed as I can unlock the handle and remove it without problem with the adapter locked in the car.
Thanks for the quick reply!It should fit since it fit the Korean Tesla CCS adapter which is exactly the same as the Tesla one (I have both). but that case you linked to us out of stock, you can probably do a custom order from Harumio for one but it is $60 instead of $45.
테슬라 모델3 Y SEXY BAG DC콤보 J1772 어댑터 하드 케이스 : bleoh
[bleoh] 유럽감성 fill the space with colorsmartstore.naver.com
Received my CCS adapter this afternoon, so I went up to the only Electrify America station in Charlotte, NC, after work. I wanted to see if I could pull more than 150kW, and Electrify America is the only non-Tesla provider that has options more than 150kW in Charlotte.
Unfortunately, I arrived with a relatively high, 40% state of charge. (I did remember to pre-condition the battery by entering the nearby Tesla Supercharger in my nav before I left home, and it was conditioned enough that the preconditioning was turning off and on.
I still pulled over 140kW for a couple of minutes, and the ramp-down curve seemed to hold higher rates for longer than a supercharger would at high states of charge. It was still charging at 80kW around 70% SOC. Even when charging stopped at 80%, it was pulling over 60kW.
Best part of all, that EA station was currently free to use.
The adapter is kind of clunky, because the CCS handle is clunky.
If you're interested in my stream-of-conscience commentary, here it is on YouTube.
I have the OEM adapter ordered via SK and the Harumio case fits SSC adapter perfectly. Seems like the spot for the J1772 is bigger than it needs to be but it still fits.Has anyone tried the official shipped from Tesla North America CCS adapter in the case from Harum (this one: Tesla Model 3/Y SEXY BAG CCS Combo 1 Adapter Case I’m sure it’s a perfect fit but would like some confirmation from someone who’s actually tried before I order.
Some kind of spacer. I don't even remember if it came with the adapter or the case. When you plug the adapter into the car it doesn't seat all the way in. I have yet to bother with the spacer, you don't need it to use the adapter.Thanks! What’s the orange thing used for?
3-4 days for me on the Left Coast.Curious how long its been taking from order to delivery in the last few days of anyone can give feedback. I'm on a road trip and considering getting a ccs adapter shipped to my friend's house who I'll be visiting in a week. Thanks!
I have the issue fixed for me.Well on the weekend I did a road trip and ended up using the adapter twice. Both time is would not lock to the handle.
I was able to put my fingers on the locking pin and move it 1/4" to 5/16" further in and that locked the handle in place.
Knowing that I need a good 1/4 or more, I don't think my idea of felt stick on would work as it may impede the closing of the door.
I may try and put something on the pin to extend it, like a rigid plastic piece of tubing.
I'm wondering if there is any difference of the pin length between Korean adapter and the one made for the US market?
Out of Spec released a video where they show a Model S Plaid getting 257kW when using the CCS adapter. (Up to 590A.)
Interesting. Even when I was charging at 190 kW in Yreka in 110 degree heat, my adapter only seemed "warm". (This is with the Korean model as well)How warm is the adapter when you pull it off at that rate? I pulled mine off after charging 50% in my Model 3 and the heat was quite scary. Of course I do have the Korea model.
